Window AC Security - Appliances - DIY Chatroom Home Improvement Forum
Old 07-10-2012, 10:04 PM   #1
Question
Window AC Security
Hello all! I am thinking about installing a window AC in a small room on the first floor; however, I am concerned about someone trying to kick in the AC in order to gain access to the house. An alarm system is present... but the insurance company would probably consider an open window, in that respect, a negative liability (you never know these days). Plus, just because an alarm system is present, that doesn't mean one's guard should be let down and worrying shouldn't be a concern. That being said, what is the best way to secure the unit to the window? It can't be permanent, obviously, because it can't be in the window during the winter months.
Any ideas?
Anesthesiologis is offline   Reply With Quote
Old 07-10-2012, 10:55 PM   #2
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,600
normally you would screw the top mounting flange of the a/c to the window and then screw a type of L bracket to the top of the window so it can not be opened. I don't know of any other way to make it any more secure.
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
Old 07-11-2012, 01:39 PM   #3
Coconut Pete's paella!
CoconutPete's Avatar
Rewards Points: 504
Your first phone call should be to your alarm company to find out if they would indeed consider it an open window.
CoconutPete is offline   Reply With Quote
Tags
air conditioning , theft , window security , window unit
wrought iron security door frame diy888 Windows and Doors 6 02-22-2016 07:08 AM
Security Window Film bonnshack Building & Construction 4 04-11-2010 10:13 AM
help need to know how to replace windows wrapped in drywall caide3 Carpentry 4 03-02-2010 12:41 PM
Problem with window and everything around it malfunction Building & Construction 3 05-26-2009 05:11 PM
