Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 09-22-2011, 01:28 AM   #1
why is my fridge leaking water inside?
Its a kenmore fridge and dripping water out that plastic piece into the container I put in the fridge. Whats going on?
milenko23 is offline   Reply With Quote
Old 09-22-2011, 07:11 AM   #2
There's a kit for this, but it's a simple DIY thingie. the waters supposed to run into the area at the back.. take that whole hse down [4 screws] and run a bead of some kind of sealer[ plumbers putty? or food grade rtv-avail at appl parts dist] around the part just forward of where the water should be going [it'll be obvious when you have it down].
Jacques is offline   Reply With Quote
Solar hot water indatom123 Green Home Improvement 0 12-19-2010 01:01 AM
My hot water recirculation system is a disaster Michael Neill Plumbing 9 11-05-2010 12:31 PM
Leaking water line needs new water regulator? huynh Plumbing 16 11-04-2010 12:32 PM
HELP: Lennox C33-36C-2F leaking water hamproof HVAC 33 06-26-2010 03:48 PM
Natural Gas Water Heater Leaking from Release Valve Pipe? psumike Plumbing 6 01-14-2009 08:18 PM
