Why Is The Dishwasher Thunking??!? - Appliances - DIY Chatroom Home Improvement Forum
Old 11-14-2012, 12:23 AM   #1
Rewards Points: 50
Why is the dishwasher thunking??!?
Help!
It's a GE Profile machine, which is running right now so I can't see the exact model.
Sometime this past year, it started thunking repeatedly as it runs. A couple times, I found "Aha! The rotating water nozzles are hitting something!"
But many times that is not the case at all. I just opened and interrupted it, and spun the top, middle, and bottom water sprayers and looked all around. They hit nothing. I cannot really tell where the sound comes from. At bottom around the base plate it is quite loud, but if I listen up by the vents it could be coming from inside. It is about once every second, more or less.
It is driving me NUTS, it is quite annoying, not just a small ticking.
What the heck could this be?
Head_Unit is offline   Reply With Quote
Old 11-14-2012, 07:17 AM   #2
Rewards Points: 14,312
http://www.repairclinic.com/RepairHe...r-making-noise
Old 11-16-2012, 12:55 AM   #3
Rewards Points: 50
Thanks!
Hmm, drain impeller, maybe? Or possible that valve. The other causes, well, the sound is not continuous, it is definitely periodic.
Old 11-17-2012, 09:16 PM   #4
Rewards Points: 530
Definitely check for debri that may be getting knocked around in the pump. If these parts snap together, make sure all are in place and snapped properly.
I found some strange things in one dishwasher I checked out.
Old 11-19-2012, 05:12 PM   #5
Rewards Points: 744
Sometimes the water jets will move stuff around.
Seattle2k is offline   Reply With Quote
Old 11-22-2012, 01:32 AM   #6
Rewards Points: 50
Had a tech over, he pulled out the baskets. Still thunking. Removing the bottom trim moldings, sounds pretty sure it is coming from the bottom i.e. the motor/pump/etc. He said "don't fix, way too expensive. No panic, you have no leaks."
Maybe I'll have to see if I can find disassembly instructions to clean it out...
Old 11-24-2012, 08:02 PM   #7
Rewards Points: 530
Might google 'free appliance manuals'.
Dishwasher Drain Install w/o Sink Lyndon Plumbing 3 11-21-2011 01:10 PM
Dishwasher connection and wiring, oh boy! Bigplanz Electrical 18 06-15-2011 09:52 PM
Replacing Dishwasher, No water shutoff sustorm Plumbing 24 04-08-2011 12:56 PM
Dishwasher installation Andy Griffith General DIY Discussions 3 03-02-2009 06:06 AM
Dishwasher placement jkrodger Remodeling 2 08-03-2007 02:32 PM
