-   -   Why is the dishwasher thunking??!? (http://www.diychatroom.com/f47/why-dishwasher-thunking-163288/)
Head_Unit 11-14-2012 12:23 AM
Help!
It's a GE Profile machine, which is running right now so I can't see the exact model.
Sometime this past year, it started thunking repeatedly as it runs. A couple times, I found "Aha! The rotating water nozzles are hitting something!"
But many times that is not the case at all. I just opened and interrupted it, and spun the top, middle, and bottom water sprayers and looked all around. They hit nothing. I cannot really tell where the sound comes from. At bottom around the base plate it is quite loud, but if I listen up by the vents it could be coming from inside. It is about once every second, more or less.
:furious::huh:
It is driving me NUTS, it is quite annoying, not just a small ticking.
What the heck could this be?
joecaption 11-14-2012 07:17 AM
http://www.repairclinic.com/RepairHe...r-making-noise
Head_Unit 11-16-2012 12:55 AM
Thanks!
Hmm, drain impeller, maybe? Or possible that valve. The other causes, well, the sound is not continuous, it is definitely periodic.
boman47k 11-17-2012 09:16 PM
Definitely check for debri that may be getting knocked around in the pump. If these parts snap together, make sure all are in place and snapped properly.
I found some strange things in one dishwasher I checked out.
Seattle2k 11-19-2012 05:12 PM
Sometimes the water jets will move stuff around.
Head_Unit 11-22-2012 01:32 AM
Had a tech over, he pulled out the baskets. Still thunking. Removing the bottom trim moldings, sounds pretty sure it is coming from the bottom i.e. the motor/pump/etc. He said "don't fix, way too expensive. No panic, you have no leaks."
Maybe I'll have to see if I can find disassembly instructions to clean it out...
boman47k 11-24-2012 08:02 PM
Might google 'free appliance manuals'.
