#1 |
Why can't they build a smart AC?
Why can't they build an AC that's aware of what's going on outside?
Why can't they make an AC unit with a feature I can set a temp and it won't go over that temp. However, if outside air temps drop BELOW it, the compressor shuts off and it sucks in outside air and blows it inside (like a window fan). Once outside temps warm up more than inside it then shuts the vent off and then waits to keep my set temp using the compressor. Call the feature "smart cooling". Seems like such a simple energy saving feature to me. Right now, I wake up at 2AM to see what the temp is outside. Typically it's 65F, so I shut off my AC's and turn on the house fan. In one hour the house fan will cool the house down better than both AC's running all night. Come morning, the house will typically be 62F-67F. I shut off the house fan & windows, turn on my AC's set to 72F, and it will typically be about 3PM before the ac units kick on, some days they don't even kick on. However, getting up at 2AM is not something I enjoy (nor do all the time so I lose out). Just seems like a simple, smart way to cool. Why cool at night using the compressor when you don't often need to. The AC should be smart enough to automatically use the compressor and recirculate air, or use outside air and just fan. Last edited by Piedmont; 06-21-2010 at 09:43 AM. |
#2 |
Xtreme DIY'r
They could build one, more expensive
It would need to check Temp & humidity You wouldn't want humid air being blown into the house And since its more $$ it probably would not sell as well I never run my AC thru the nite....can't sleep But it doesn't get as hot up here We use mostly ceiling fans & window fans |
#3 |
i imagine it's because it's not universal enough, in other words would be unnecessary in many very hot areas of the country, like where i live. for about 90% of the time the A/C needs to be on from april through october, the outside temp never gets low enough to warrant this feature. manufacturer's would have to be able to mass market something like this and the cost must justify the savings. for that 10% of the time you are talking about, the extra cost and complication would outweigh the overall benefit.
#4 |
why don't you put that stuff on a timer or programable thermostat.
#5 | |
Why can't they build a smart AC?Quote:
![]() I think it would be more useful than 10%, I would guess anyone living in hardiness 7 and below would find it a useful feature especially the further away from 7. Most of the country is hardiness 7 or below, but most population dense states (Texas, California, Florida) are not. Maybe 40% of the population of the USA would find it useful & energy efficient. Maybe electricity is cheap other places, I'm paying $0.22/kWh. I see my Kill-a-watt meter displaying if I continue as I am right now I'm looking at $330 this year for cooling a small ranch in New England using a one year old Energy Efficient AC. If that feature cuts my cooling down by 1/3rd (which I believe is conservative) that's a savings of $110/year. Mileage can vary as you pointed out. Last edited by Piedmont; 06-22-2010 at 06:17 PM. |
#6 |
Why can't they build a smart AC? |
#7 |
Wire Chewer
That would be cool if they made that. Basically there could be a secondary return with a damper (whole vent and damper would need to be very well insulated) so when the AC is on it would either turn the unit on, or turn this damper on, based on the house temperature, outside temp/humidity.
#8 |
this is easily a project for a -competenet-DIY. for instance have a/c's on a timer or a receptcale controlled by a /prog'therm' and a separate temp or time controlled vent [many homes have attic mounted fans that are controlled that way] you could also control your house fan this way, you'd just have to wire the pro/therm on fan only to go on at a certain time or temp.
#9 |
Lots of commercial heat/AC package units have that feature, it's called an economizer. Has a control that senses outdoor temp and humidity and opens a damper to bring in outside air if the parameters are met. More meant for places that need cooling when it's 30-50 degrees out though. Night time temps in the 60's also have humidity levels in the 80-90% range so they will not bring in outside air under those conditions. Even though the temp is cool bringing in humid air adds more load for the system , more $ to run, then just leaving the AC on.
BTW 22 cents a KW is crazy! Ours is closer to 8 cents. |
#10 |
The cam gear pump works fine for filtered WVO or used motor oil Babington heaters and I have installed it on my Babington style heaters. Ldu Company's stock number is 450516 , The only thing about the cam gear pump is that the fire kind of pulses as the cam gear rotates. If you use the spur gear pump that is LDU's stock number 450512 then you get a steady non-pulsing fire. The WVO pump website is http://www.liangdianup.com/subpages/oilpump_1.htm or you can click through to the tools section from the home page at www.LDUcompany.com
LDU Company also has other parts that I use for building my waste oil burners, like gear reduction motors. I find it best to turn the pump slower because you really don't need a whole lot of oil dripping on the atomizer ball. |
#11 |
Wire Chewer
Out of curiosity, how would one go about adding an outside intake anyway? It would need to be much larger then a typical dryer vent for example. This is a very big hole in an outside wall, that needs to be properly insulated, with a good damper, and also have very good protection against burglars, animals, bugs, and the elements (water, snow, flying debris from wind etc). I'm guessing a serries of grids would need to be used, maybe a pre filter to catch dust particles and so on before they hit the furnace filter. Even having this as a manual setup would be pretty neat. It would be a very quiet way of bringing in outside air and distributing it evenly. Would also be cleaner if you have a good filter system, vs a whole house fan that relies on windows to be open.
#12 |
Average Joe/ex-Navy IC3
They actually do make thermostats that use sensors, and also Internet connected ones that use weather info to watch what is going on, track use, make changes, etc. As for a unit to be smart enough, this is where that gray matter up in your noggin comes into play.
| Display Modes | |
| Mid Roof Smart Vent and ice dams | mbergm57 | Roofing/Siding | 5 | 10-14-2011 06:49 PM |
| time to build simple addition | bmt1970 | Building & Construction | 9 | 03-05-2010 03:06 PM |
| What trim is more water resistant and holds paint better: Miratec or Smart Trim? | Studly | Building & Construction | 4 | 10-03-2009 08:45 AM |
| Build or buy a shed and costs? | Piedmont | Building & Construction | 7 | 05-19-2009 08:13 PM |
| To Build or Not To Build | scoby1978 | General Discussion | 6 | 05-27-2007 05:39 PM |
