Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 08-01-2012, 10:30 AM   #1
White stuff on dishes
Our machine is 12 years old but has always done a good job on the dishes. All of a sudden its leaving heavy white deposits on everything and they are not coming off.
Any suggestions?
Meller is offline   Reply With Quote
Old 08-01-2012, 10:44 AM   #2
creeper's Avatar
Before you go and take the thing apart, check the label on the dishwashing detergent. Up here, the stuff with phosphates has been banned and subsequently the dishes are not coming as clean.
If the label says phosphate free, Id try a different brand. The only brand that works for me since the ban is Finish-Quantum-powerball
creeper is offline   Reply With Quote
Old 08-01-2012, 10:53 AM   #3
Mine has been doing the same thing, and it's only a few years old. What works for me though is if I do a hot wash or heavy wash cycle the white deposits don't show up.
Dwillems is offline   Reply With Quote
Old 08-01-2012, 11:03 AM   #4
Mine does that when the holes in the arms are clogged. I take the arms out and run water through them under the sink to find the clogs, then use tweezers to pull the particles out of the holes. It's usually something like a popcorn hull. Reinstall and fixed! I use the opportunity to clean out any traps, etc. at the same time.
Vinegar will also remove any white deposits you have on your dishes or silverware. We found we need to do that before they'll ever come clean again once it's coated, especially the silverware.
Pianolady is offline   Reply With Quote
Old 08-01-2012, 07:10 PM   #5
Piano lady is right. Lime scale deposits are typically the culprit. Clean the wash arms and sump and run a few loads of vinegar.
Protocol. is offline   Reply With Quote
White stuff growing on concrete 1948glw Flooring 1 12-03-2011 10:01 PM
fuzzy white stuff on walls marybur2 Painting 2 11-07-2011 10:25 PM
glazing white builder grade cabinets - how to get this look? denemante Painting 1 11-04-2011 08:13 AM
White residue from my dishwasher on my dishes. Chris Woodruff Appliances 1 10-31-2011 08:21 AM
Off White Trim/Base/Crown with White Ceiling/Doors? StyxTx20 Interior Decorating 4 12-15-2008 08:54 AM
