White Particles In Water From Fridge - Appliances - DIY Chatroom Home Improvement Forum
Old 01-02-2011, 11:47 PM   #1
White Particles in water from fridge
All of a sudden in the water from my fridge there is white stuff floating around. This is an LG fridge that's about 1.5 years old. I just replaced the filter, but that didn't work. Any ideas?
JoeyJoeJo is offline   Reply With Quote
Old 01-02-2011, 11:53 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Those fridges usually have a large plastic coil of pipe hidden at the back wall to cool the water. The pipe may have collected some mineral deposits as the result of a bad filter. The location of the coil is typically (after) the filter does its job. So...it could be releasing deposits and the filter won't help it. If this is what is taking place, and if the filter is maintained the flakes should play out over time.
XXX
Old 01-02-2011, 11:58 PM   #3
That's good to hear. Thanks!
Old 01-03-2011, 12:04 AM   #4
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Hold on!
That's just a guess on my part - it is the first logical reason that comes to mind.
XXX
Old 01-03-2011, 12:17 AM   #5
Well, I'll give it a few days and see how it goes. I'm hoping you're right.
Old 01-03-2011, 12:32 AM   #6
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Good luck!
XXX
Old 01-03-2011, 06:24 PM   #7
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,600
Bud would be correct, that white stuff is lime and or mineral deposits
hardwareman is offline   Reply With Quote
Lost Hot water pressure brile Plumbing 11 11-28-2010 03:59 PM
White residue - well water system kirk374 Plumbing 4 11-22-2010 08:01 AM
Older GE Fridge no Ice WorldOfJohnboy Appliances 3 09-10-2009 08:39 PM
Water tube to fridge... Wolf_22 Appliances 9 04-04-2008 01:36 PM
No Water Flowing To Fridge garyb123 General DIY Discussions 5 12-24-2007 01:28 AM
