Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 06-21-2009, 12:37 AM   #1
Unhappy
whirpool duet front-loading washer F-30
What does F-30 mean? I am pretty sure the code is F-30. My cycle will start, but it doesn't finish. The softener doesn't go in at all. What is happening?
Thanks for any advice.
chilimaiden is offline   Reply With Quote
Old 06-24-2009, 06:22 PM   #2
Quadfam4's Avatar
I just looked it up and it sounds like its a dispenser motor malfunction. they say its an inexpensive fix.
Quadfam4 is offline   Reply With Quote
Old 06-29-2009, 01:58 AM   #3
This problem is caused by the diverter arm. Open the top of the washer by removing the screws in the back. Once removed you will see the detergent mixer box and an arm on a cam. sometimes by just readjusting this arm you can fix the problem. run the unit through its cycles and when it gets to the dispenser just gently nudge the arm If this does not work the mechanism needs to be replaced. Usually when this error occures it will have a grinding or popping sound.
robert1633 is offline   Reply With Quote
LG Front Loading washer on second floor Mr Chips Appliances 11 10-20-2012 09:23 PM
Whirlpool Duet front loading washer drain pump Jrr1099 Appliances 1 04-08-2009 02:57 PM
Kenmore front loading washing machine rtyui2 Appliances 1 01-05-2009 12:46 AM
Front Load Washer handy man88 Appliances 3 07-01-2008 11:16 AM
Recommendations on Front Loaders Washer/ Dryer helpless handyman Appliances 6 02-15-2008 11:59 AM
