Whirlpool Washer Will Not Spin Dry - Appliances - DIY Chatroom Home Improvement Forum
Old 08-02-2013, 06:01 AM   #1
whirlpool washer will not spin dry
i have a older,prob 12 years,whirlpool top loader. it will fill and wash but will not drain and spin dry. i have heard that the latch for the top may not be sending a closed signal and requires replacement. does this sound right? any other ideas would be helpful. i dont want to get too deep in this old washer.
chizlr40 is offline   Reply With Quote
Old 08-02-2013, 06:06 AM   #2
Rewards Points: 14,020
Please post the model #.
Yes you may be right, simple enough to check the switch.
digitalplumber (08-09-2013)
Old 08-02-2013, 07:24 AM   #3
ok will check when i get home later today and repost
Old 08-02-2013, 08:09 AM   #4
Rewards Points: 6,652
If direct drive, the Rubber pieces and plastic fitting that dampen the motor noise between the transmission and vertical shaft may be torn, or the plastic pieces. Move it out of the way and look for oil spots on the floor beneath it. If there is, the transmission is gone. Good news is, the transmissions on these things run about $187-225, the rubber pieces & plastic fittings about $11.
This is the motor coupling I am talking about http://www.repairclinic.com/PartDeta...85753A/1195967 This is what the transmission parts look like http://www.repairclinic.com/Whirlpoo...e-Clutch-Parts
Old 08-02-2013, 08:25 AM   #5
Here's some generic ideas of things to look for. With a model number it will be more specific.
http://www.repairclinic.com/RepairHe...her-won-t-spin
Old 08-08-2013, 03:26 PM   #6
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,600
will not drain or spin probably lid switch. Will not spin could either be motor coupling or lid switch. Is the tub still full of water?
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
The Following User Says Thank You to hardwareman For This Useful Post:
Whirlpool Cabrio Washer WTW7340XW0 Sounds Like a Jet during Spin TinaV Appliances 16 04-10-2016 07:58 PM
Frigidaire Affinity front loading washer 2006 model-won't spin final spin? imola ghost Appliances 9 10-23-2015 04:23 AM
GE Washer will not perform final spin joeycranston Appliances 6 01-18-2010 11:06 PM
GE washer No spin when loaded SPSNEXPERT Appliances 4 06-29-2009 12:39 AM
Maytag washer spin cycle problems. billmac Appliances 1 07-16-2008 04:03 PM
