Whirlpool Washer Stops - Appliances - DIY Chatroom Home Improvement Forum
Old 04-08-2008, 10:16 AM   #1
Whirlpool washer stops
The washer stops in mid cycle and will not run.
Power to the machine is ok.
Any assistance is appreciated.
whirly_p is offline   Reply With Quote
Old 04-08-2008, 10:54 AM   #2
Custom Cabinet Maker
sounds like a timer
skymaster is offline   Reply With Quote
Old 04-08-2008, 12:38 PM   #3
What is the model number of your washer and how old is it?
Will the washer still agitate?
Will it do anything if you manually move the timer?
Check the lid switch.
If you need a switch for your washer you can get your Whirlpool parts Whirlpool parts here.
girltech is offline   Reply With Quote
Old 04-08-2008, 12:45 PM   #4
jeff1's Avatar
Hi,
Lack of info....
Top load, front load, model#?
Stops in the same place all of the time? Where on the dial?
What still works? Stops dead with no noises?
jeff.
Appliance Repair Aid
www.applianceaid.com
JRAppliance
www.jrappliance.ca
jeff1 is offline   Reply With Quote
Old 04-08-2008, 03:38 PM   #5
Thanks for the response
Top load = yes
Model # LSW97OOPQ0
While working the machine stopped ad will no longer work.
Old 04-08-2008, 04:07 PM   #6
jeff1's Avatar
Model # LSW97OOPQ0
That will be LSW9700PQ0
A Whirlpool direct drive style washer.
Still doesn't tell us WHAT works and WHEN it quits....but, definetly check the lid switch!
http://www.applianceaid.com/direct_drive_spin.html
Where on the dial?
What still works?
jeff.
JRAppliance
www.jrappliance.ca
Old 04-09-2008, 07:05 PM   #7
Thumbs up
Whirlpool washer stops "solved"
It was the lid wsitch. Thanks for the effort
Whirly_p
Old 04-09-2008, 10:59 PM   #8
jeff1's Avatar
Thankx for the update!
jeff.
JRAppliance
www.jrappliance.ca
Old 04-11-2008, 03:25 PM   #9
prodgod's Avatar
Just had a similar problem with our 14 year-old washer and my wife was getting frustrated. Meanwhile, based on the advice I read here, I jiggle the lid switch and PRESTO! Back in business.
Thanks for not only saving us a hefty service call and repair bill, but ALSO for making me look like a total home-improvement stud!
prodgod is offline   Reply With Quote
Old 04-11-2008, 04:42 PM   #10
jeff1's Avatar
If Mama is not happy......nobody is happy!
jeff.
JRAppliance
www.jrappliance.ca
Removed basement stairs - put in floor for washer and dryer capslock Flooring 3 10-09-2010 02:15 PM
Whirlpool dishwasher odor Captflx Appliances 8 06-26-2009 08:40 PM
220V Washer 3-pronged to 220V dryer-outlet Primergy Electrical 19 03-27-2008 10:40 PM
Washer drain peloncito Appliances 7 08-04-2007 12:56 AM
Location of 220 and 110 outlets for dryer and washer JAJJ Electrical 2 08-07-2006 09:16 PM
