Whirlpool Washer Model #LSQ9549LWO - Appliances - DIY Chatroom Home Improvement Forum
Old 03-19-2012, 12:00 AM   #1
Rewards Points: 83
Whirlpool washer model #LSQ9549LWO
My wife told me that there was a strange sound before she turned the washer off. It was about to start the rinse cycle. I found a appliance parts website and it appears this washer uses a direct drive. Can anyone who has this model provide me an advice on what possibly failed and if they fix it on their own? Sounds like its not going to be easy. thanks.
hawaiiboy is offline   Reply With Quote
Old 03-19-2012, 12:19 AM   #2
Rewards Points: 83
I should add that the bucket does not turn at all and that this strange sound comes on when i set the dial to the rinse cycle which I suppose the washer is currently set at. I can email you a video if you wish. Just pm your email msg. Thanks
Old 03-19-2012, 03:21 AM   #3
So what are you saying? That she heard a strange sound and that is why she shut it off?
If so, there is probably something stuck in the water pump.
jammin06 is offline   Reply With Quote
Old 03-19-2012, 08:56 AM   #4
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,600
need way more info here. Does it still agitate? does it spin? does it pump out? have you tried it again. Whirlpool washers are very easy to work on, so provide more info
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
Old 03-19-2012, 12:58 PM   #5
Rewards Points: 83
No agitation no pump out. Just the sound of the motor whirling.
Old 03-19-2012, 06:18 PM   #6
#1 HAWKEYE FAN
no spin? sounds like the moor coupler broke, but even with the coupler broken it should still pump the water out.
The Following User Says Thank You to hardwareman For This Useful Post:
hawaiiboy (03-20-2012)
Old 03-20-2012, 02:39 PM   #7
Rewards Points: 83
Thanks. I drained all of the water from the bucket before I read your response. I'd like confirm the pump is still working by filling it with water and see the water will be drained. Meanwhile do you know where I can get info to replace the moor coupler and is it easy to change?
Old 03-21-2012, 02:22 AM   #8
Rewards Points: 83
Filled the bucket with water. Turned to the rinse cycle and the water drained out. Pulled the motor out and found a broken coupler. Thx.
Old 03-25-2012, 05:36 PM   #9
Rewards Points: 83
I slapped on the new motor coupler and isolater rubber piece. I also pulled out the agitator. I noticed that the directional cogs were worned. Anyway after putting everything back I ran the washing machine. Noticed an awful electrical burning smell.
Old 03-26-2012, 08:59 AM   #10
#1 HAWKEYE FAN
should be ok but you may want to pull the coupling again and make sure it is all the way on the motor and all the way on the trans shaft. no binding and everything is lined up perfectly. Maybe put a little lube on the shafts first so you don't have to force them on so hard.
Creaking - Whirlpool Duet Front Load Washer homerb Appliances 2 01-03-2012 11:30 PM
Whirlpool clothes washer overflowed dismas Appliances 3 05-27-2011 10:39 AM
GE Profile Washer Model WPRE6100G0WT neither agitates nor spins tammy2006 Appliances 5 02-13-2010 02:33 PM
Whirlpool washer leak billmac Appliances 1 08-08-2008 05:18 PM
Ge Washer Model # Gf900483g Help Help Help WOW12344 Appliances 1 04-16-2008 10:51 PM
