Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 09-21-2012, 02:50 PM   #1
Question
Whirlpool Washer Inlet Valve Leak
The inlet valve on my washer (LSR8233EQ0) is leaking. A local plumbing shop gave me a free replacement part; however, it is just a tad different than the original.
He gave me
http://www.partselect.com/PS2021369-...Thermistor.htm
And this is the original part
http://www.partselect.com/PS334646-W...ng-Bracket.htm
It looks like the only difference is the temperature sensor. Any reason I can't just use the free one?
NoneGiven is offline   Reply With Quote
Tags
inlet valve, leak, washer
Leaking washer - source of leak? stephenbishop Appliances 9 04-24-2012 05:30 AM
Leak near main supply shutoff valve. cSquall Plumbing 2 07-25-2011 10:36 PM
Is inlet valve required for "cold in" on water heater? joemontana16 Plumbing 8 11-29-2010 08:15 PM
Bleeder Valve Leak jwfran Plumbing 1 05-08-2006 09:12 PM
Water heater drain valve leak Fletcher33584 Plumbing 3 02-28-2006 08:07 PM
