Whirlpool Washer Burned Start Capacitor - Appliances - DIY Chatroom Home Improvement Forum
Old 11-14-2015, 01:40 PM   #1
Rewards Points: 4
I have a Whirlpool Gold series, direct drive washer, model GSX9885JQ0. The start capacitor burned and melted. Also, one wire, not connected to the capacitor, appears to have been over heated as well. Subsequently the machine won't agitate or spin as the motor won't kick on. I took the whole thing apart: the motor spins freely while on the bench and all winding are within spec; there is nothing jammed in the water pump; the centrifugal start switch passes a bench test, gearbox spins freely and reverses gears when turned by hand on the bench; agitator is fine. Also note: the machine did not shut itself down as it would if the motor overheated, and the were no failure codes displayed. So.....why did that cap melt? I have a theory, but don't know how to explain it. So, first I thought I'd throw the question out there and see if anyone has had the experience. I'm pressed for time as there are 5 people in the house all waiting for me to solve the problem. Anybody want to help me here? Thanks.
kfhaggerty is offline   Reply With Quote
Old 11-22-2015, 02:48 PM   #2
Rewards Points: 4
Issue resolved; bad cap, one burned wire, and one open wire.
Vibration In High Speed Spin Mode Davy49 Appliances 7 12-30-2014 10:47 AM
Creaking - Whirlpool Duet Front Load Washer homerb Appliances 2 01-03-2012 11:30 PM
washer will not start badnews582008 Appliances 1 05-25-2009 12:46 PM
Buying a Hard Start Capacitor Help D1G1T4L3CH0 HVAC 3 10-17-2008 09:42 PM
How do I know which start capacitor to get? Prince Electrical 8 09-16-2008 10:59 AM
