Whirlpool Side By Side - Appliances - DIY Chatroom Home Improvement Forum
Old 12-21-2010, 08:59 PM   #1
Whirlpool side by side
It will cool and then it wont
TRACY SMITH is offline   Reply With Quote
Old 12-21-2010, 09:09 PM   #2
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,584
a little more info please. how long does it cool? what do you do to get it to cool again? how old ? does the freezer freeze? what is the freezer temp?
hardwareman is offline   Reply With Quote
Old 12-21-2010, 09:19 PM   #3
IT WILL GET DOWN TO ABOUT 5 AND SHUT OFF AND WONT START AGAIN AN THEN AFTER A SHORT TIME THERE IT GO AGAIN
Old 12-21-2010, 10:05 PM   #4
#1 HAWKEYE FAN
so your saying freezer temp gets to about 5 degrees shuts off and then won't restart until it warms up considerably? sounds like maybe a defective cold control. next time you catch if doing its thing, try cranking the control way up and see if it kicks on then
Old 12-22-2010, 08:57 AM   #5
Do work
Rewards Points: 81
Check this out.
liquidvw is offline   Reply With Quote
Whirlpool refrig. problem ken1415 Appliances 146 09-17-2016 07:46 PM
sears side by side refridgerator not cooling - freezer working dkusko Appliances 0 09-05-2010 12:22 PM
Should I use a vapor barrier on each side? Hossenfeffer Building & Construction 3 04-09-2010 11:12 PM
Whirlpool side by side refrig: accessing the ultra ease to replace the water spout rituals Appliances 1 06-29-2008 08:44 PM
Whirlpool side by side getting very HOT ericdean Appliances 2 03-07-2008 01:26 PM
