Whirlpool Refrigerator: No Ice Or Water!!! - Appliances - DIY Chatroom Home Improvement Forum
Old 01-26-2007, 10:34 PM   #1
Whirlpool refrigerator: No ice or water!!!
Whirlpool side by side refrigerator: ed5phexmb1 (about 2 1/2 years old)
I am not getting any water to my ice maker and barely a trickle from the water dispenser on the door. Suspected water pressure since I have a RO and water softener hooked up. Before replacing the RO filters I had 20 psi, now I have 30 psi to the refrigerator . I checked the pressure just before it goes into the solenoid and I still have 30 psi, but barely a trickle out of the solenoid...
Question #1
Is there anything else I can do to test out the solenoid to see if it has gone bad, i.e. voltage, resistance...?
Question #2
Water pressure!?! Should I invest in a booster pump to get the pressure up? Into my house I am getting 60 psi, the closest point from the water softener and water heater (basement) is 50 psi (cold) and 40 psi (hot). Upstairs (split level house; 1800 ft²) I am getting 40 psi to the RO system.
tarwood is offline   Reply With Quote
Old 01-27-2007, 07:37 AM   #2
jeff1's Avatar
Hi,
ed5phexmb1
I got ED5PHEXMB10 and ED5PHEXMB00
Refrigerator filter is new/ok?
If we have good water flow into the valves and the valves are getting 110-120 volts ( have someone push the water paddle for you while you measure with volt meter ) but poor flow out would make the fill valve suspect.
Many manufactures tell us 20-120psi is required for d/w, fridge, a/w fill valves to work, your on the low end but should be ok.
Ice and water filter in front access grille
Water inlet valve kit with new quick connections and instructions
jeff.
Appliance Repair Aid
www.applianceaid.com
JRAppliance
www.jrappliance.ca
jeff1 is offline   Reply With Quote
Old 01-27-2007, 10:14 AM   #3
I didn't think the "0" was part of the model number, since there was a sapce, but I have the ED5PHEXMB10.
Actually I removed this filter due to redundency; with the water softener and RO system is this still needed???
I'll check the voltage and let you know, much appreciated.
Terry
Old 01-27-2007, 02:24 PM   #4
jeff1's Avatar
Probably not...was more concerned it hadn't been changed...a tired filter will lower the water pressure in the refrigerator.
jeff.
JRAppliance
www.jrappliance.ca
Old 11-14-2008, 01:33 AM   #5
this is really cool site, thanks for the idea that you have posted here in your forum
Refrigerator Filters
jshunter is offline   Reply With Quote
Old 11-20-2008, 08:05 PM   #6
You may have a restriction in the valve or in the resevour. Pull the valve out of the frig (leaving all lines hooked up). Take the line off the valve that goes to the built in filter. Put a bucket under the valve and push the button to dispense some water. Do you get a good flow??? If no: your valve is restricted. If yes, hook the line back up and take the line coming out of the water resevour and repeat the test. Is the flow ok?? Just a matter of eliminating lines until you find the restriction. 30psi should be plenty of pressure.
sv9779 is offline   Reply With Quote
Changing filter in Whirlpool whole house water filter farnamct Plumbing 7 12-20-2012 09:11 PM
Gravity Hot Water Recirculating Loop Questions harleysilo Plumbing 2 02-06-2007 03:28 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 10:31 AM
help Chuckman Off Topic 8 06-15-2006 10:06 PM
whirlpool water heater THEBIGPUNN Plumbing 1 02-01-2006 08:31 AM
