Whirlpool Refrigerator Leaking - Appliances - DIY Chatroom Home Improvement Forum
Old 04-22-2013, 08:12 PM   #1
Whirlpool refrigerator leaking
I have a Whirlpool Gold Series refrigerator model# GI7FVCXWB00 that is leaking from underneath in the back. It leaks approx 1/3 cup daily. I clean it up when I come in from work and leaks again the next day while I'm at work. I disconnected the water supply but still leaks. I'm attaching a pic of a part where the leak puddles up in the general area of this part. Could you give me the name of the part, its function and if it could be the cause of the leak.
Thanks for your help!
RayD is offline   Reply With Quote
Old 04-22-2013, 08:32 PM   #2
Rewards Points: 13,300
http://www.repairclinic.com/RepairHe...er-GI7FVCXWB00
Old 04-23-2013, 03:58 PM   #3
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,600
maybe its just me but I can not enlarge your photo to tell what it is. Can you repost?
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
Old 04-23-2013, 03:59 PM   #4
#1 HAWKEYE FAN
[QUOTE=joecaption;1165201]http://www.repairclinic.com/RepairHelp/How-To-Fix-A-Refrigerator/59-5-704400-/Whirlpool-Refrigerator-leaking-water-GI7FVCXWB0
Old 04-23-2013, 07:37 PM   #5
Rewards Points: 1,452
This is the result of defrosting, which is controlled by an automatic cycle, about every 24 hours. The ice forms on the coils inside, usually between the freezer and main refrigerator compartments, and there are channels for the condensate down to near floor level in back.
Is (was) there a tray underneath that is supposed to catch the water?
Dust and sediment can also perturb the flow path of the condensate so it misses a tray and ends up on the floor.
Old 04-24-2013, 09:30 AM   #6
I'm pretty sure that the pic I posted is a water inlet valve. I ruled it out by pulling it out and leaving out from underneath so if it was leaking it would leak directly onto the floor. I left the cover off and have been watching the last couple days. I observe water in the condensation pan but some water is getting outside the pan even though it isn't full and into the steel bottom of the refrig between plastic pan and compressor. I suspected a crack even though I dried the pan out and couldn't see one. I put some clear silicone sealant where I thought a crack might be and will find out this afternoon if it helped.
Thanks for all the help so far. Those I great links that were posted
Old 04-29-2013, 11:49 AM   #7
FYI, the leak was from a cracked drip pan. Removed and replaced, so far no more leaking. Thanks for the posts because they really did help this DIY'er
Thanks again!
Proper grounding of whirlpool.. valcarmo72 Electrical 12 02-20-2013 04:22 PM
Replace My Whirlpool Water Heater with Which Brand? hermes Plumbing 6 03-17-2012 10:42 PM
Whirlpool GFCI circuit info conflict. 3detailer Electrical 29 05-17-2010 10:12 AM
Problems with Whirlpool Dryer Hookup! Help! maryrgrimm Appliances 1 04-07-2010 08:42 AM
Relocating drain/trap in manufac. home for whirlpool, HELP!!! MikeVila Plumbing 7 12-10-2008 10:04 PM
