Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 02-04-2012, 01:12 PM   #1
JH6
Whirlpool Refrigerator Dripping from freezer into fridge.
I have about a five year old Whirlpool black fridge, standard size, no icemaker.
The problem is that water is dripping from a drain hole inside the fridge (near the light bulb).
I have been catching it in a tupperware container, it is about 1 cup per day or less.
It is a standard top freezer unit, the bottom of the freezer also has ice forming on it.
What should I do with this unit? Anyone know where the drain tube is, I think it might be clogged? Is it inside the freezer or on the outside of the unit.
Thanks,
Justin
JH6 is offline   Reply With Quote
Old 02-04-2012, 02:15 PM   #2
The drain/drip pan will be located behind the back wall of the freezer . Should be two-four screws in the corners of freezer back wall. Once you take panel off you should see the evaporator coils and underneath will be your drain/drip pan. Most likely it will be frozen over a soils block of ice running the lenght of the drip pan. Take a hair dryer to it to melt.ice and use hit water to pour into pan and make sure water flows/drains freely . The end of the line will be located behind your fridge at the bottom behind back panel.
acestarservices is offline   Reply With Quote
Old 02-04-2012, 02:25 PM   #3
JH6
thanks for the help, I will try this once the tenants use up some of the food in the darn freezer.
Whirlpool fridge freezer JEVINGTON Appliances 1 07-10-2011 06:26 PM
kenmore fridge too warm, freezer iced up tarbash11 Appliances 5 06-30-2011 11:32 PM
Help My Admiral Refrigerator is leaking water Cuwillis Appliances 9 03-22-2011 09:40 PM
Whirlpool Fridge Freezer Display Flicker Herts198 Electrical 1 02-27-2010 01:08 PM
Freezer leaking into Fridge? jc2709 Appliances 1 05-23-2007 10:55 AM
