Whirlpool Refrigerator Defrost Promlem - Appliances - DIY Chatroom Home Improvement Forum
Old 03-26-2010, 11:51 AM   #1
Whirlpool refrigerator defrost promlem
Hi everyone!
I have a whirlpool refridgerator #GD5RHAXNQ00. It is not cooling like it used to. I removed the back panel in the freezer and the finned coil
was covered in ice. I checked the heating coil for continuity and its ok.
Is there a sensor that controls the defrost or is it done by way of that
circuit board in the white box at the bottom of the refridgerator.
My Beer is not as cold as it should be!
Mark
markf is offline   Reply With Quote
Old 03-26-2010, 04:36 PM   #2
Rewards Points: 276
My experience has been defrost timer.
Jim F is offline   Reply With Quote
Old 04-06-2010, 08:03 PM   #3
Rewards Points: 1,494
Usually it is timed interval, such as 30 minutes of the heating element every 24 hours. Look for a little round stud about the diameter of a pencil that you can turn using a large screwdriver. Usually it is on the top panel of the refrigerator compartment towards the back, but sometimes it could be outside on the back and you have to pull the fridge away from the wall. Sometimes turning the stud frees up the timer if it got stuck but you need to keep an eye on it and be prepared to replace it. Sometimes you can hear the refrigerator go into the defrost interval by the sound of a fan and stopping of the compressor, as you turn the stud, otherwise it is trial and error to activate the defrost interval manually.
Problems with Whirlpool Dryer Hookup! Help! maryrgrimm Appliances 1 04-07-2010 07:42 AM
Support under whirlpool bath tub? cherylcrawford Building & Construction 6 11-19-2009 03:36 PM
Kohler Whirlpool wont turn on swieder Appliances 0 10-04-2009 11:54 AM
Whirlpool Fridge Ice Maker just quit igorlord Appliances 5 02-28-2009 07:49 PM
Relocating drain/trap in manufac. home for whirlpool, HELP!!! MikeVila Plumbing 7 12-10-2008 09:04 PM
