Whirlpool Range Oven Temp Swing - Appliances - Page 2 - DIY Chatroom Home Improvement Forum
Old 07-27-2011, 11:31 AM   #16
Originally Posted by hardwareman View Post
60 degree swing is not acceptable you must have a bad sensor.
I decided to order a new temp sensor and will ohm out both then it comes in.
horrocks is offline   Reply With Quote
Old 07-29-2011, 04:20 PM   #17
Received and installed the new sensor. The old one measured about 1100 ohms at room temperature. With the new sensor I am still getting a total difference of 60F. Must be the control board unless +/- 30F is the spec.
Old 07-29-2011, 05:56 PM   #18
Update. I ran the oven longer and further adjusted the calibration to try to center at 350F for the 350F setting. After it cycled a couple of times, I noticed that the differential temperature was tighter than before. Instead of 60F total swing, I got a 47F swing. I had to set the calibration at -25F to obtain the temperature match. I probably will live with this for a while and see how my wife likes it. At any rate, it should be running 25 degrees cooler than before. Less chance to burn the cookies.
Old 12-03-2011, 09:09 PM   #19
Erratic Temperatures
Hello Hardwareman,
I have been following this thread and it is very interesting. It appears this fellow is using an electronic oven. I am not sure but mine is a manual type stove/oven combo.
I am experiencing some very erratic temperatures. Cookies are burning as one person stated earlier. Whirlpool RF3020XPN is my model number.
Will your resistance readings in this thread correspond with readings for my temperature sensor?
I would like to give it a whirl as far as checking resistance readings with external thermometer readings to try to correct this problem.
Is there anything else in particular I need to look out for?
Thanks in advance for your professional assistance.
Regards,
Scott Lawrence
scottk4sl is offline   Reply With Quote
Old 12-03-2011, 09:25 PM   #20
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,582
the ohms readings would be very similar no matter what sensor your oven has. I have found that very erratic temps swings come from a bad board rather than a bad sensor but by all means check the sensor first.
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
Old 12-04-2011, 12:35 PM   #21
Awesome man thanks a bunch. Will get back with ya within the next couple of days.
Old 12-05-2011, 08:07 AM   #22
Another thing to keep in mind is; you have to let it preheat for 30min-ish. especially on todays electronic controlled ovens. the oven after preheat cycle [if so equipped] shuts off is *not* at temp indicated on display ie; 350*. this is done on purpose by manf' for bragging rights to accu temp control. seems counter intuitive but they say it's an engineering method for even heat. so any crictal baking like cakes/cookies or checking temps-preheat the 30min.
Jacques is offline   Reply With Quote
Old 12-05-2011, 08:50 AM   #23
Hi Jacques,
Thanks for the info. This is an old manual type stove with dials etc. Does it still have to preheat 30 mins?
Scott
Old 12-05-2011, 09:31 AM   #24
#1 HAWKEYE FAN
OK, hold the phone. I should have looked at your model#. You will have no sensor, you have a thermostat with a capillary tube. If your temps swing that much you will have to replace the thermostat.
Old 12-05-2011, 12:32 PM   #25
Awesome Hardwareman!!!
Thanks for the information. A thermostat should be easy to replace. Do you by chance have a part number for it? Actually a service manual would be awesome so I can take a look at the circuitry as well.
You folks are awesome.
Many thanks!!!
Scott
Roper Electric Oven Range Problem mcnutty Appliances 6 07-05-2011 06:32 PM
Whirlpool Oven Element Cultcab Appliances 5 01-04-2011 09:21 PM
Old gas kenmore range....no oven, but burners work shadango Appliances 24 11-17-2010 07:45 AM
Oven Door question for Amana Gas Range ChrisJJ Appliances 1 09-13-2010 07:48 AM
Range outlet pushes oven too far from wall givemeabreak Electrical 8 08-19-2008 01:14 AM
