-   -   Whirlpool Range Oven Temp Swing (http://www.diychatroom.com/f47/whirlpool-range-oven-temp-swing-111838/)
horrocks 07-24-2011 05:35 PM
What is the expected temperature swing in an electric Whirlpool stand alone range?
hardwareman 07-24-2011 10:53 PM
depends on the thermometer being used, a regular oven thermometer it should stay within 5 degrees.
horrocks 07-25-2011 07:57 AM
I am using a $30 Pyrex thermometer where you do not have to open the oven to read it. My swing is about +/- 30F
Jessidog 07-25-2011 09:54 AM
I have an inexpensive thermometer that hangs from the oven rack so it can be read without opening the door. My oven also stays within 5 degrees, but no more than 10 degrees of the set temperature. I have a Kenmore, but I think it is a Whirlpool product.
David
hardwareman 07-25-2011 12:04 PM
far to much, you either have a bad sensor or a bad thermostat, depending on model.
Jackofall1 07-25-2011 01:51 PM
Sounds like burnt cookies to me:yes:
Mark
But I agree with hardware man on the sensor
horrocks 07-26-2011 11:16 AM
I decided to call Whirlpool and ask them the question on the oven temp swing. As usual, I was disappointed in their help. Not a clue. No specification available. It would be nice to find a design engineer in the right department. I am sure there is a spec some place. Further, it would be neat if I could find a service manual which would provide voltage or resistance readings for various temperatures.
hardwareman 07-26-2011 12:14 PM
you haven't posted a model # but I'm just going to throw this out for reference. If you stove has a temp sensor and not a thermostat, the ohms readings for the sensor would be approx:
room temp 1000 ohms
300 degrees 1550 ohms
350 degrees 1650 ohms
400 degrees 1750 ohms
horrocks 07-26-2011 12:32 PM
room temp 1000 ohms
Looks like it is linear. My model is GFE461LVB 0. If the temp sensor is okay, then it may be a hysteresis problem with the temp controller.
horrocks 07-26-2011 05:31 PM
I obtained the technical service info for my range. The temperature adjustment instructions do not match that of the owners manual and do something different. I went into diagnostics and found that the oven sensor is measuring ambient temp at about 12-14 F low. I believe this reading is independent of the calibration adjust and not affected by such. This may be why I had to adjust the temp calibration the other day to a minus 30F. I believe even though the temp sensor may have drifted, it still may be working correctly as far as temp changes. Not sure though. So, at this point, if the temp differential should be less than +/- 30F then it still could be either the temp sensor or the control board. I would hate to buy a board at about $150 and find out no difference, but I might go for the $50 temp sensor.
hardwareman 07-26-2011 08:43 PM
did you ohm the sensor?? If the sensor ohm out correctly then you need to replace the board.
hardwareman 07-26-2011 08:55 PM
I think you are over analyzing this. Here is how you check the temp of oven with a thermocouple probe type thermometer.
Preheat oven to 350 let it cycle 2 times
take temp reading at its high point then take temp reading a low point, do this twice.
average out the results: example oven cycles at high point of 360 low point 345 first reading
second reading 362 high 348 low add them all together for a total of 1415 degress divide by 4 = 353.75 degress. That would be dead on balls accurate. You should be able to recalibrate your electronic control + - 25 degrees. If its over 25 degrees off set temp then ohm out sensor with the measurements I posted before.
horrocks 07-26-2011 09:03 PM
I will ohm out tomorrow. I can recalibrate +/- 30F and I know I can achieve the average temp to be at the set point, but, I want to know what temp variation is acceptable. My high to low is about 60F.
hardwareman 07-26-2011 09:30 PM
60 degree swing is not acceptable you must have a bad sensor.
