Whirlpool Oven Element - Appliances - DIY Chatroom Home Improvement Forum
Old 01-04-2011, 03:39 PM   #1
Rewards Points: 49
My mother has an old Whirlpool Oven (RB100PXYB) and the lower element stopped working. The broiler element will come up to temperature when the oven is turned on, but the lower element stays cold. Is there a way to check if this is an internal wiring problem or if the element has burned out?
Cultcab is offline   Reply With Quote
Old 01-04-2011, 04:22 PM   #2
Whats up with Whirpools quality? it has dropped so much
Sandra20 is offline   Reply With Quote
Old 01-04-2011, 04:55 PM   #3
Rewards Points: 48
I have correctly diagnosed the few that I have dealt with, as well as a couple of stove top and dryer elements, with an ohm meter, and I think that this would be a good place to start, obviously with the power OFF. The only thing is that, as best as I can recall, the ones that I dealt with had no continuity, so they were pretty obvious, and I don't know how much resistance a good element should have. If you have a volt meter, you could then check to see if you have voltage to the element, but be careful.
Old 01-04-2011, 06:01 PM   #4
Rewards Points: 49
Dexter - the broiler element is still working, so I should be able to compare the resistance between the two.
I haven't pulled the back of the oven off - do you remember if the ends of the element were easy to get to?
Old 01-04-2011, 06:42 PM   #5
Rewards Points: 48
I don't know that I have ever worked on a Whirlpool, specifically, but believe that there are a lot of similarities between brands. Regardless, I don't recall ever spending too much time getting to the problem, and, although it's been a while, I'm thinking that you don't need to go through the back, but I may be wrong. Boy, I wish that I could remember more things, but it seems to me that the most you have to do is remove a couple of screws where they connect to the range.
Old 01-04-2011, 09:21 PM   #6
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,600
remove 2 screws from the element inside of oven, pull element, remove wires, ohm the element.
hardwareman is offline   Reply With Quote
Oven Blew Up at Connector with Element cynthiap Appliances 6 10-31-2015 10:48 AM
Whirlpool Oven removal k4thdan Appliances 4 11-25-2010 08:19 AM
Whirlpool oven removal k4thdan Electrical 3 11-23-2010 03:42 PM
Bottom (bake) element in the oven dead? elementz Appliances 3 04-19-2010 08:40 AM
Whirlpool Build In Oven jogan Appliances 0 12-02-2009 07:50 PM
