Whirlpool Oven And Broiler - Appliances - DIY Chatroom Home Improvement Forum
Old 12-30-2011, 05:03 PM   #1
whirlpool oven and broiler
i replaced the spark ignighter on the bake and it still won't heat or broil, what could be the problem
cyna is offline   Reply With Quote
Old 12-30-2011, 05:23 PM   #2
Rewards Points: 14,026
When you turn the valve to the light position can you see the ignitor sparking?
If it is then there's no gas flow, pluged up oriface would be my guess.
Old 12-31-2011, 08:10 AM   #3
This is a somewhat complicated system for a DIY. if you don't want to throw parts at it-call a local servicer familar with direct spark ignition.
Jacques is offline   Reply With Quote
SCARY oven fire! Why did it burn? Beth777 Appliances 73 09-03-2016 02:19 PM
Wall oven broiler not firing up all the way! Gaffers & Sattler Bozo4ovens Appliances 2 03-11-2011 08:20 AM
Whirlpool Oven Element Cultcab Appliances 5 01-04-2011 08:21 PM
Gas oven problems gregsmy Appliances 1 12-03-2009 05:55 AM
GAs Oven works broiler does not .... fburke Appliances 1 09-23-2008 09:16 PM
