Whirlpool Microwave/oven Comnbination Problem - Appliances - DIY Chatroom Home Improvement Forum
Old 10-29-2012, 04:45 PM   #1
Whirlpool Microwave/oven comnbination problem
I have a whirlpool microwave built in with an oven. The microwave will not start when start is pressed. It clicks off and the display loses the clock setting. every thing else seems to function normally including the minute timer and the clock(after i reset it) The microwave wont come on reliably. sometimes it will work for one try but usually shuts itself off before the timed interval is up.
So is there a repair?
Does the entire unit (microwave and oven) have to be replaced. I assume so since the oven controls are built in to the microwave panel...
Model RM286PXV3 built in 1992
vvgogh is offline   Reply With Quote
Old 10-30-2012, 09:02 AM   #2
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,584
1992, it has served you well.Time to let it go. By the time you pay a qualified service tech to come out and diagnosis it and repair it (if parts are even available} you will have a lot of money tied up it in. Probably best to put that to wards a new over the range micro and new range.
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
Need Help Fixing Damp Slab Problem in Shop OlyTDI Building & Construction 10 10-30-2011 01:35 AM
Kenmore (Whirlpool?) Ice maker problem reddog6 Appliances 4 10-09-2011 07:11 AM
Double Bowl Kitchen Sink Drainage Problem PeteW Plumbing 16 09-05-2011 10:41 AM
75 year chimney leak problem mstanleyg Building & Construction 10 03-30-2010 01:38 PM
Stymied by window leakage problem. Matth3w General DIY Discussions 5 06-11-2008 07:26 PM
