Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 04-27-2008, 09:51 PM   #1
Whirlpool Microwave light issue
Microwave is model # MH6130XEQ
My wife was cooking dinner tonight and hit the button to turn on the light underneath the microwave so she'd have some extra light on the stove and she said she heard something pop like the little light bulb blew or something. I noticed there was no power at all to the microwave so I checked the breakers in the breaker panel and sure enough one had flipped so I flipped it back to normal position and the microwave came to life again. The weird thing is that now the light won't go off. You can push the light button all you want but it doesn't go off or cycle through the Hi-Low-Off setting either. I tried unplugging the microwave for 30 seconds or so to let it reset but as soon as I plugged it back in the light is on. Again, this is the light underneath with the vendhood thing. The fan runs like normal the microwave still works to heat food. Just can't get the light to turn off. Thanks in advance for any help.
mustangcobra44 is offline   Reply With Quote
Old 04-28-2008, 12:51 AM   #2
jeff1's Avatar
Hi,
MH6130XEQ
Found MH6130XEQ0 MH6130XEQ1 MH6130XEQ2
Sounds like the board was damaged and now is stuck in the on position....all of the time.
Power control board
jeff.
Appliance Repair Aid
www.applianceaid.com
JRAppliance
www.jrappliance.ca
jeff1 is offline   Reply With Quote
Old 05-01-2008, 10:40 AM   #3
Hey Jeff, thx for the info. I realized that we got a home warranty when we bought the house last year so I called and the microwave is covered. $60 deductible to get it fixed. Cheaper than the power board so figured it was the best way to go. I'll post back after repairs are done with what the issue was.
Old 05-01-2008, 01:12 PM   #4
jeff1's Avatar
Good deal!
Great.
jeff.
JRAppliance
www.jrappliance.ca
Old 05-06-2008, 11:32 AM   #5
Alright Jeff, repair guy said the same thing you did.
Part is on order and we'll know shortly for certain if that's the culprit.
Old 05-06-2008, 02:25 PM   #6
jeff1's Avatar
Thankx for the update!
jeff.
Old 05-19-2008, 04:13 PM   #7
Stick another feather in the ol' hat Jeff!! Part finally came in and took the repair guy all of about 5 minutes to get it put in. All is working great (we even think the LED display is a bit brighter but may just because it was off for a couple weeks).
My back is feeling better so may be about time to tackle the fridge and it's icemaker issue now.
Old 05-19-2008, 07:08 PM   #8
jeff1's Avatar
Glad to hear that
jeff.
JRAppliance
www.jrappliance.ca
Old 08-14-2008, 04:52 PM   #9
Found this thread and hope you can help. I have the same microwave and the lights don't work. Have obviously changed the bulbs but still no light. Not sure where to go from here.
Any thoughts would be appreciated.
Wahoo100 is offline   Reply With Quote
More On This Topic
Hi! This is Jon on behalf of expertvillage.com. In this video clip I’ll be talking about the safety switch. The safety switch is located on the front of the planer. To turn it on, what you’ll do is go ahead and flip it up, and to turn it off... Read More »
Hi! I'm Kay and we are filming for expertvillage.com here at Carter's Appliance in Fontana, California. And then you have produce bins for both vegetables and fruit. Of course, you have a different configuration for shelving. Some shelves are stationary... Read More »
Alright now, this apartment complex is actually really old. So it only has 2 breakers for every little unit and my unit is this one right here 3 quarters and it only has these 2-20 amp breakers. So, this is all I really have to do; that's it. This is the... Read More »
Michael Raines. Expert Village. Now, we're under the sink. We've deduced that our switch is still good. So now the problem must be under the sink with the disposal. Now, what most people don't realize is there is a reset switch on modern disposals. Some... Read More »
Hey, I'm Mark Sullivan, and today we're going to show you how to replace a porcelain receptacle. This is a light fixture, you can do this yourself. What the problem with this one is it has broken. It's supposed to go "click, click", so what we're going... Read More »
Can't remove Whirlpool Over the range Microwave kzukowski Appliances 9 07-22-2009 01:35 PM
Need to replace can light with standard light Woodcutter Electrical 3 02-29-2008 08:06 AM
replacing vanity light...issue with outlet box? tarheelblue Electrical 5 01-28-2008 10:20 AM
Light fixture issue baustin Electrical 4 07-17-2007 05:01 AM
Hot Light Outlets Materials Guru Electrical 5 07-31-2006 08:11 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
