-   -   Whirlpool Mark I Just died, need help (http://www.diychatroom.com/f47/whirlpool-mark-i-just-died-need-help-100467/)
KarlJay 04-04-2011 01:06 AM
I have a Whirlpool Mark I side by side w/sevadoor ice/water.
It's been next to the gas oven which I've been using as a heater till I install a new furnace. The freezer side got pretty warm because of the heat. I'm guessing it was running pretty hard.
It's been holding up fine, but died today. The light still comes one, but no cold air.
I looked at the back and found what looks like a fuse that sits very near the compressor. It also has what might be a fuse behind the water control valves. It's where the power cord comes into the rear.
Question,
Is there a reset switch on these?
Is there a fuse?
I can't find the model number, is there a standard place they put these?
I've check inside, outside...
Is there a website that has a step by step to walk someone thru things to check?
Thanks, KarlJay.
KarlJay 04-04-2011 03:12 AM
Ok no fuse at the junction box. I found a small coil thing on the compressor, I pressed it up from the under sided. It doesn't look of feel like a switch, but I plugged it back in, played with the on/off inside and then she came back on.
Pretty strange, I wonder if that's a funny looking reset switch, it didn't feel like a switch and the whole thing has cooled down to normal temps.
Anyone know where the reset switch would be?
Jacques 04-04-2011 07:23 AM
There's no reset. that coil thingie is the relay to start the comp..next time it does this[temps warm etc] rap the "on/off" with the handle of a screwdriver or something similar. if it comes back on it's =the cold control...DANGER-you know you're dumping a lot of CO into the house by using the gas oven for heat..
KarlJay 04-04-2011 01:22 PM
I've heard about the CO, so I bought a detector just for that. It didn't register any, they only time the CO alarm went off was when I had my car (old muscle car) idleing in the driveway.
The relay has a part the sits next to the compressor, I figured it was an overheat switch, so after the fridge started working again, I put that relay box back on.
So at this point, I have NO CLUE why it stopped working and why it started working again. My guess would be some kinda internal reset, but why did it wait that long, the heat was off all day and everything was at room temp for a long time.
Guess I'm moving the fridge soon! Dam things cost so much $$, can't risk it going bad.
KarlJay 04-04-2011 03:31 PM
Ok, it just stopped again. Water is leaking out the freezer side door. This makes me wonder if it's something to do with the defrost cycle timer getting stuck. I don't know if/when it'll start back up. Is there some check I can do to determine if the defrost is bad?
KarlJay 04-04-2011 03:46 PM
Ok, looks like I found the solution. Inside the top of the fridge part is a plastic cover. It covers the light, temp knob, and what I thought was a sensor. The sensor is inset withing the box that has the temp knob. I just stuck my finger in there and the fridge started working again.
I'll try to post a pic later, but does anyone know what this inset push button switch next to the temp selector is?
KarlJay 04-04-2011 05:48 PM
2 Attachment(s)
Here's a pic of the button that I've been pushing in order to get the fridge to kick back on. It worked last night, then this morning was not running. I pushed the button and it worked.
Each time it shuts down, theres a small puddle of water on the freezer door side of the floor.
The button is below the switch and left of the temp control. This is the top inside the fridge part of a side by side.
Any clues would be great, thanks, KarlJay.
hardwareman 04-04-2011 08:34 PM
good detective work, that is your defrost timer. Instead of pushing it you should be able to turn it. I suspect you found your problem.
KarlJay 04-04-2011 09:54 PM
Ok, so I'm guessing that turning this is going to increase / decrease the amount of time or temp that the defrost runs. But, if it doesn't restart then the unit could be bad.
Is there a way to test the unit?
Does it work off temp or time or both?
hardwareman 04-04-2011 10:49 PM
turning it will advance it into or out of the defrost mode. No way to really test it, if you find your refrigerator not running and warming up then turn it, if it starts you have your problem solved. replace the timer.
