Whirlpool Imperial Series Gas Dryer Troubleshooting - Appliances - DIY Chatroom Home Improvement Forum
Old 09-14-2011, 01:57 PM   #1
Whirlpool Imperial series gas dryer troubleshooting
Need help troubleshooting an issue with my Whirlpool Imperial series gas dryer. The dryer gets warm but never gets hot. I cleaned out the vent (which didn't have any build up) and have verified that air is flowing through the system as it operates. I'm kinda confused because it gets warm so it doesn't seem as though the ignitor, valve, or thermostat would be bad.
Any advice on this problem? Thanks in advance.
koz123 is offline   Reply With Quote
Old 09-14-2011, 02:46 PM   #2
Experienced
Jackofall1's Avatar
Might be an obvious question but needs to be asked, did you change the setting on the controls, from say perma press to delicates or something of that nature.
Mark
Old 09-14-2011, 02:48 PM   #3
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Could be a the heat coil is severed but not yet separated and continuity is bouncing back and forth, it will eventually burn out totally if that's the case.
It may also be a two element system with one element gone out.
There are also resistors involved, "thermistors" I was told (here) recently that could also have failed.
The two "thermistors" and the coil can be verified with a continuity tester if you don't want to call a servicemen.
If all of this leaves you in a cloud then call a repairman.
Old 09-14-2011, 02:49 PM   #4
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Good one Jack, didn't even think of that.
Old 09-14-2011, 03:08 PM   #5
Experienced
Jackofall1's Avatar
Your electrical knowledge astounds even a seasoned pro, but the OP did mention the dryer was a.......wait.......wait.....a gas dryer.....
Mark
Old 09-14-2011, 05:30 PM   #6
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Well SCHIT!
Missed that entirely in my zeal to be helpful. Okay I'll go stand in the corner on my own, you won't have to tell me.
Old 09-14-2011, 08:23 PM   #7
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,600
most likely you have a weak solenoid coil on your gas valve. Watch the dryer cycle for a few times to see what happens. Usualy when the coil gets weak it will open the gas vavlve for a few cycles but after that nothing.
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
Old 09-14-2011, 08:35 PM   #8
Experienced
Jackofall1's Avatar
Well SCHIT!
You can come out now, but you have to eat your vegetables and tonight is cauliflower and no cheese.
Mark
Old 09-14-2011, 08:48 PM   #9
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Do you know what the difference is between cauliflower and bugers?
You can't get kids to eat their cauliflower.
Old 09-14-2011, 08:51 PM   #10
Experienced
Jackofall1's Avatar
Wait let me get my glasses, I think there is a hint in the question......
Old 09-20-2011, 03:52 PM   #11
Thanks for all your help. I replaced the solenoid coils and everything is working well. The employee at the parts store that I got the coils from said this is a typical failure for gas dryers.
Thanks again!
Old 09-20-2011, 04:05 PM   #12
#1 HAWKEYE FAN
your most welcome and thanks for reporting back
Old 09-20-2011, 04:24 PM   #13
Tileguy
Bud Cline's Avatar
Rewards Points: 558
I have nothing more to say!
convert whirlpool dryer from 4 to 3 prong? kevanalthuis Electrical 2 08-19-2011 07:40 PM
Whirlpool Dryer SHOCK dolemite Appliances 2 08-13-2011 01:45 PM
Lp conversion to propane whirlpool dryer 1judyb62 Appliances 1 07-24-2011 10:56 PM
Problems with Whirlpool Dryer Hookup! Help! maryrgrimm Appliances 1 04-07-2010 07:42 AM
Worth fixing whirlpool estate elect. dryer? dbldee20 Appliances 2 05-10-2009 04:40 PM
