Whirlpool Icemaker Wiring Question - Appliances - DIY Chatroom Home Improvement Forum
Old 03-27-2009, 05:46 AM   #1
whirlpool icemaker wiring question
I have a whirlpool sidemount icemaker that has a broken plastic post in the center of the dial on the power module. I have a replacement whirlpool(new for free) icemaker from a friend. This icemaker has a screw in the dial. Original ice maker has a plug in the power module but the new one looks like the wire is molded into the power module. Will this unit work correctly if I splice the wires and if so what would the wire color connection be?
dannyb is offline   Reply With Quote
Old 03-27-2009, 09:46 AM   #2
No, the icemaker you got will not work and I do not recommend splicing the wires. You can replace the electronic head or the whole icemaker.
Last edited by Scuba_Dave; 09-30-2010 at 11:50 AM. Reason: removed adv link in post
applianceman is offline   Reply With Quote
Old 03-28-2009, 07:45 PM   #3
whirlpool icemaker wiring problem part 2
Thanks for your reply. I believe that I can fix my original icemaker if I just had the white cam that has the posts that the dial fits onto. I discovered that the "no ice" bar had probably been forced and that kept the gear from turning freely. It seems ok now if I just had this piece replaced. I looked on the whirlpool site and the icemaker parts list for my model fridge was completely different from what I have. Do you know the model of my icemaker and where I can get the partlist and maybe also the part? It's the Whirlpool with the ice maker on the side and it has the power module with all the test points and the split plastic pin holding the dial on.
Old 03-28-2009, 08:45 PM   #4
As far as I know you can’t get just that part you have to buy the module/motor the part number is 628366.
Wiring Question bahaisamurai Electrical 3 02-22-2009 11:06 AM
Whirlpool Icemaker Stopped Working jablizz General DIY Discussions 1 07-19-2008 08:38 PM
whirlpool icemaker problem pbl1962 Appliances 2 12-26-2007 02:07 PM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 01:19 AM
Trane Heat Pump tstat replacement with Honeywell prog - wiring question sep23 HVAC 2 10-20-2006 09:10 PM
