-   -   whirlpool icemaker wiring question (http://www.diychatroom.com/f47/whirlpool-icemaker-wiring-question-41189/)
dannyb 03-27-2009 05:46 AM
I have a whirlpool sidemount icemaker that has a broken plastic post in the center of the dial on the power module. I have a replacement whirlpool(new for free) icemaker from a friend. This icemaker has a screw in the dial. Original ice maker has a plug in the power module but the new one looks like the wire is molded into the power module. Will this unit work correctly if I splice the wires and if so what would the wire color connection be?
applianceman 03-27-2009 09:46 AM
No, the icemaker you got will not work and I do not recommend splicing the wires. You can replace the electronic head or the whole icemaker.
dannyb 03-28-2009 07:45 PM
whirlpool icemaker wiring problem part 2
Thanks for your reply. I believe that I can fix my original icemaker if I just had the white cam that has the posts that the dial fits onto. I discovered that the "no ice" bar had probably been forced and that kept the gear from turning freely. It seems ok now if I just had this piece replaced. I looked on the whirlpool site and the icemaker parts list for my model fridge was completely different from what I have. Do you know the model of my icemaker and where I can get the partlist and maybe also the part? It's the Whirlpool with the ice maker on the side and it has the power module with all the test points and the split plastic pin holding the dial on.
applianceman 03-28-2009 08:45 PM
As far as I know you can’t get just that part you have to buy the module/motor the part number is 628366.
