Whirlpool Icemaker Problem - Appliances - DIY Chatroom Home Improvement Forum
Old 12-23-2007, 12:08 PM   #1
whirlpool icemaker problem
i have a whirlpool refrigerator (model #gs5shaxnbo1) which has a problem with the icemaker. it is not filling the icemaker with water. i havve taken the icemaker unit out, performed various checks, and things look ok here. i ohmed out the icemaker motor and its about 4k, which i believe is correct.
at this time i think the problem lies within the main control board that is located at the back of the unit near the compressor (part #2304095) i dont see any signs of burnt components, however i dont seem to be getting 120 vac coming off the tan wire going to the icemaker solenoid. note that the recieving led is on steady when the icemaker flopper door is depressed, which i understand to mean the sending and recieveing units are ok.
anyone have a smiliar problem?
pbl1962 is offline   Reply With Quote
Old 12-25-2007, 11:33 AM   #2
Pro Painter
Did you check the water line to see if you have water coming in?
Maybe your water line freeze.
TroyM is offline   Reply With Quote
Old 12-26-2007, 03:07 PM   #3
I don't believe the water line to be an issue. I am getting water from the dispensing unit in the front of the fridge. Just not seeing 120 vac get to the icemaker solenoid. The sending and recieving "eyes" seem to be ok.
Whirlpool refrig. problem ken1415 Appliances 147 Today 01:27 PM
Whirlpool Side By Side Not Making Ice Anymore!! handy man88 Appliances 57 07-14-2011 07:33 AM
Whirlpool Icemaker RIPNLIPS Appliances 3 11-01-2007 10:21 AM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 02:51 PM
