Whirlpool Icemaker Not Working - Appliances - DIY Chatroom Home Improvement Forum
Old 07-22-2009, 08:20 PM   #1
Smile
Whirlpool icemaker not working
I have a Whirlpool GD5RHAXNB00 that wont make ice. Here is what I've done, replaced icemaker module, checked the infered sensors ok. Have only 34VAC at BK/WH wire, not near enough. HELP
jtec62 is offline   Reply With Quote
Old 07-23-2009, 06:09 AM   #2
RE : Whirlpool icemaker not working
I would call the provider and they provide the instructions to check if you have power. The covering in the front of the ice maker can be removed and there should be a few little holes that are labeled either by numbers or letters. You'll need a heavy gauge wire to check to see if you have power.
polljimmy is offline   Reply With Quote
Old 07-23-2009, 06:27 AM   #3
Smile
I think I may have found the problem, I have 120VAC going into the inffrared emitter board and into the reciever board but only 34VAC coming out of reciever baord to to icemaker module/ motor....i'll let you know how it works out
whirlpool icemaker and water dispenser not working pal723 Appliances 3 03-18-2012 09:50 PM
whirlpool icemaker wiring question dannyb Appliances 3 03-28-2009 08:45 PM
Whirlpool Icemaker Stopped Working jablizz General DIY Discussions 1 07-19-2008 08:38 PM
whirlpool icemaker problem pbl1962 Appliances 2 12-26-2007 02:07 PM
