Whirlpool Icemaker Advice - Appliances - DIY Chatroom Home Improvement Forum
Old 11-24-2008, 10:46 AM   #1
Question
Whirlpool icemaker advice
I have a Whirlpool side by side (model ED25PW). Ice maker stopped making ice. At first it was filling up not only the trays but the reserve area but now is not making any ice. Water dispenser is working fine. I tested the solenoids and get the same reading for the water and ice. I also flushed the line going into the ice maker and removed the silver tube inside and made sure it was not blocked. Still no ice. I have not been able to find the filter screen but the line is clear. What now??? Any advice would be appreciated.
diymomof4 is offline   Reply With Quote
Old 11-27-2008, 08:49 PM   #2
Where are the icemaker fingers pointed? The resting position should be about 2 oclock. If not pull the cover off and look at the shaft on the big gear. Chances are it's broken.
sv9779 is offline   Reply With Quote
Old 11-30-2008, 08:10 PM   #3
If you are handy with a volt-ohmmeter, you can pull off the toe plate from the front bottom of the fridge and you should find a service sheet on the icemaker. It will be folded up and stuck in the back of the toeplate. If you pull off the front of the icemaker mechanism, there are test points accessable. If the fridge is fairly new, the little motor is probably toast.
hoistdoctor is offline   Reply With Quote
whirlpool icemaker and water dispenser not working pal723 Appliances 3 03-18-2012 09:50 PM
Whirlpool Fridge Icemaker thelocke1 Appliances 4 10-28-2008 11:39 PM
Whirlpool Icemaker Stopped Working jablizz General DIY Discussions 1 07-19-2008 08:38 PM
whirlpool icemaker problem pbl1962 Appliances 2 12-26-2007 02:07 PM
Whirlpool Icemaker RIPNLIPS Appliances 3 11-01-2007 09:21 AM
