Whirlpool Icemaker - Appliances - DIY Chatroom Home Improvement Forum
Old 09-17-2007, 02:50 PM   #1
Whirlpool Icemaker
All
have a whirlpool side by side. Ice maker will not work. There is ice in the maker but the machine will nlt dump it. Prior to this there was water on the floor below icemajker. Water fill part works fine. Thanks for any help and a drawing would be appreciated
RIPNLIPS is offline   Reply With Quote
Old 09-18-2007, 11:48 AM   #2
I had a similar problem with my Kichenaid. It turned out to be a broken wire in the wiring harness that runs from the door to the main body.
db819 is offline   Reply With Quote
Old 11-01-2007, 08:22 AM   #3
Long-Listed John
Take a hiar blow dryer to it and it may dump the ice. Mine is mesed up and someone said to do that. It did dump the ice in the maker, but wnn't fill now. But you have water so it may solve it all. Buddy paid 80 to have a tech do it for him. Fixed it in his case, but it did crap out months later. May be they don't last but so long, I don't know.
John Pride is offline   Reply With Quote
Old 11-01-2007, 09:21 AM   #4
The freezer has to be cold enough for the ice maker to work. Usually, when the ice maker stops working, it may be a sign of problems with temps. So first make sure your freezer isn't getting warmer. Might be a defrost problem, look for frost build-up on the back wall of your freezer.
cjett is offline   Reply With Quote
Whirlpool tub doesn't work Scott_K Plumbing 16 01-05-2015 05:02 AM
Copper tubing for icemaker? BigJimmy Plumbing 15 09-11-2011 02:23 PM
Whirlpool Side By Side Not Making Ice Anymore!! handy man88 Appliances 57 07-14-2011 06:33 AM
icemaker Nancy Barrett Appliances 3 12-11-2006 10:15 PM
tile step into whirlpool ekaplan1020 Remodeling 1 04-09-2006 10:48 AM
