WHIRLPOOL Ice Maker Won't Dispense Water - Appliances - DIY Chatroom Home Improvement Forum
Old 09-24-2010, 01:52 PM   #1
WHIRLPOOL ice maker won't dispense water
My ice maker works if I manually fill it with water, but it won't dispense water. It is not clogged with ice. The in door water dispenser works fine. Any suggestions?
martizar is offline   Reply With Quote
Old 09-24-2010, 02:27 PM   #2
DIY Hack
Mr Chips's Avatar
Rewards Points: 506
it could be the motor that pulls the water,
you could have a tiny piece of debris in the line, especially if you are on a well and ran it low.
The arm that tells it the tray is full can be stuck,
someone could have turned the supply valve off.
are you sure the line isn't frozen inside anywhere?
Those who can, do...
Those who can't criticize on the internet
Mr Chips is offline   Reply With Quote
Old 09-26-2010, 07:03 PM   #3
Post
See if this helps. Many brands are similar, especially older models.
http://www.geappliances.com/service_..._icemakers.htm
diyorpay is offline   Reply With Quote
Whirlpool Ice Maker DanCarmo Appliances 1 08-21-2010 10:12 PM
Oil fired furnace and hot water heater question steveinpa Plumbing 3 08-10-2010 08:42 AM
bad valve washing machine?? drdon51 Plumbing 6 06-29-2009 01:02 PM
Very Low Hot Water Pressure. PAS1970 General DIY Discussions 2 02-25-2009 03:01 PM
No water on door or Ice maker sagahafer Appliances 3 11-27-2008 08:18 PM
