Whirlpool Ice Maker Stops Midway - Appliances - DIY Chatroom Home Improvement Forum
Old 07-14-2009, 03:01 PM   #1
Whirlpool ice maker stops midway
Whirlpool modular ice maker kit.
About 4 years old.
It fills water fine, ejects the ice then it stops.
If I push the arm down, it will work again and follow the cycle noted above and stop.
Any ideas?
Thanks!
Elyse
gusfam is offline   Reply With Quote
Old 07-14-2009, 03:41 PM   #2
Household Handyman
Rewards Points: 1,408
You stated that " If I push the arm down, it will work again and follow the cycle noted above and stop." Why is the arm up at the end of the cycle? If I remember correctly the arm will move up about halfway up as the ice cubes are dumped and then should return to the down position as the next cycle begins. When the arm is at the uppermost top position, indicating a full ice container, this should tell the icemaker not to make ice. I'm no expert on appliance repair but have two refrigerators with the Whirlpool style icemakers that work this way. It sounds as if something in the cycle timer has gotten a little off. I don't have the solution to this though, sorry. Good Luck, David
Old 07-14-2009, 07:49 PM   #3
The arm stops about halfway up, not in the "off" position. But then it never cycles again.
The ice maker is empty when this happens.
Kenmore (Whirlpool) refrig ice maker problem lexort Appliances 18 05-07-2016 09:28 AM
Whirlpool Ice Maker Control Kaput? Mike Swearingen Appliances 11 06-09-2011 06:46 AM
Whirlpool Ice Maker has stopped making ice jpetersen5 Appliances 7 04-13-2008 06:13 PM
Whirlpool Ice Maker Problem Aquin Appliances 5 03-26-2008 12:59 PM
