Whirlpool Ice Maker Heater Dead - Appliances - DIY Chatroom Home Improvement Forum
Old 12-16-2009, 09:13 PM   #1
Question
Whirlpool Ice Maker, Thermostat Problem?
Model GS5SHAXNL. Water supply is fine, ice maker fills and freezes. Ejector arms attempt to eject ice but cannot eject because the heater does not activate. Tested the heater with ohm meter, about 70 ohms, another web site said it should be 60-90 ohms so heater appears ok. Thermostat measures 0 ohms when cold and about 4500 ohms warm...I believe it should be infinity when warm? Bad thermostat? Any other thoughts?
Thank you!
Mike
Mtn4Mike is offline   Reply With Quote
Pilot on Williams millivolt wall heater goes out every 8 to 16 hours wornways HVAC 30 06-22-2011 03:29 PM
(Water Heater MYSTERY) Hot water out from dead tank with cold water in it? Inayity Plumbing 6 07-14-2008 08:36 PM
Whirlpool Ice Maker has stopped making ice jpetersen5 Appliances 7 04-13-2008 06:13 PM
