I have a Whirlpool ED5FHAXS side by side with the in door ice storage.
I have my water line going through a water purifier (always have) and therfore do not use the in fridge filter. Currently my ice maker is not making ice. I am still getting water through the door, so that line is good, but no water is going into the Ice Maker tray.
Any idea what could cause this to happen? Or better yet, how I can go about fixing it. I called Whirlpool and they immediately told me to open a service ticket and have someone come out, but I thought I would try this first.
I may have found the issue, but I am going to try the self diagnostic thing if I can find the tech sheet....
It seems that my problem may be that my water line comes from a reverse osmosis system. I have never had a problem before, but reading it says that it requires a specific water pressure 301-20 PSI. I called the guy that installed my softener and RO system and he said that if the filter needs to be replaced, which I think it does, this could slow down the water pressure enough to the point where the ice maker won't make ice anymore. He siad even lowering the pressure to 29PSI could cause me issues. He told me that the line could be frozen and suggested, 1, replacing my system filter, and 2, taking a hair dryer to the water output area by the ice tray to thaw any potential freeze in the line...
Any experts here agree with this?!
Is there a better place to blow the hair dryer. All I see as exposed in a little black rubber part that comes down from the top of the fridge and into the tray. That part has no freeze to it, but I imagine something up in the fridge ties into that part and thats where the freeze might be. Would blowing hot air into this black part be good to thaw any potential freeze higher in the line!?
OK, I replaced my filter to up the water pressure and then took a blow dryer to the little tube coming down from the ceiling of the fridge, but I don't know how long I should have done this for and since I don't see a spot where there is actually a frozen line, I don't even know if this did any good...
I am still not getting ice. Can anyone explain exactly how the blow dryer to thaw a frozen line should work. How long, where I do it, etc..
If the water pressure drops low enough going to the fridge the water valve on the fridge would not close which would cause the ice maker to over flow and the water dispenser would not shut off.
So the water pressure is not an issue.
If the line was frozen it would likely take about 15 to 20 minutes to thaw but you have to be careful not to melt any of the plastic.
The ice make will not work if the temperature is above 5 degrees.
Did you find the technician sheet?
Try turning the fridge off or unplugging it. If the compressor is running when you unplug it wait twenty minutes and then plug it back in.
Wait a little while and then see if the ice maker got any water.
I have a problem that you may have solved for me. When I disconnect the electrical power to the icemaker water valve and turn on the water, water flows through the valve into the freezer. I've replaced the valve (twice actually), with the same results. I've just tested the continuity between the coils on the valve, and the results are fine.
The icemaker is connected to a reverse osmosis system. Could that system cause the normally-closed valve to remain open? Sounds weird, but I'm at a loss if that isn't the culprit.
Thanks, Jeff. I'll try to bypass the reverse osmosis system to see if the valve closes with no electrical power.
Thanks again,
Malcolm
Related Threads
DIY Home Improvement Forum
3.1M posts
319.6K members
Since 2003
