-   -   Whirlpool Ice Maker Control Kaput? (http://www.diychatroom.com/f47/whirlpool-ice-maker-control-kaput-5019/)
Mike Swearingen 11-25-2006 11:56 PM
Hey Jeff (and All Other Experts),
Have 2001 Whirlpool Side-by-Side Refrigerator Model # GD22DFXFB02 with outside ice and water dispensers in freezer door.
Ice maker suddenly stopped making ice. It isn't frozen up (bone dry in fact, and it's not calling for refill water). All else is fine, including the water filter and the ice water dispenser.
I removed the control mechanism on the front of the ice maker to look at the back of it, but I couldn't tell anything just by looking.
Would it be that main control or some water control valve just to the ice maker of some sort on the back of the fridge?
TYIA,
Mike
jeff1 11-26-2006 07:47 AM
Hi Mike,
How?
Sitting there dead, going through the motions but not filling with water, stuck 1/2 way though a harvest?
We usually first always confirm...is the icemaker getting power or not getting power.
Model # GD22DFXFB02
Module style icemaker...
http://www.american-appliance.com/im...mbreakdown.gif
SERVICING
The design of this ice maker allows all of the components to be tested without removing the ice maker or moving the refrigerator away from the wall to access the water valve.
Remove the cover and you will see the test points identified on the module.
N =Neutral side of line
M Motor connection
H Heater connection
T= Thermostat connection
L = Ll side of line
V =Water valve connection
No power to the icemaker may be a wire/thermal fuse problem, power into the icemaker and no go is an icemaker issue.
Hope something here helps :)
jeff.
Mike Swearingen 11-26-2006 10:19 AM
Thanks, Jeff!
The ice maker is just sitting there dead, not stuck on anything, and not going through any motions. No ice or water in it. It's just dead.
I have a copy of that service sheet, so I'll use your information that supplements it to check things out with my electrical tester.
I'll let you know what I find.
Thanks,
Mike
jeff1 11-26-2006 03:20 PM
Great! :)
jeff.
Mike Swearingen 11-26-2006 10:37 PM
Jeff,
Voltage meter test: no power to module. Ohm meter test: O.K.
Where is the thermal fuse? Is there more than one? (I have the wiring diagram, but I don't know how to read all the symbols.) I see something in the "Refrigerator" Section that says "Thermo", but I don't know if the symbol is for a fuse. Does a fuse symbol resemble three sides of a rectangle sticking up out of a straight line? Is it an inline fuse, such as those in my boat wiring? Does "bimetal" indicate a fuse? Would I see it easily if I pulled the refrigerator out?
Thanks for any help,
Mike
jeff1 11-27-2006 07:05 AM
Built into the wire harness...
http://www.repairclinic.com/dbimages...7/00085361.jpg
The white and black slug.
Nope, normally a thermostat is called a bymetal as it can heat and and open or cool down and close.
Does a fuse symbol
-Some- common ones...
http://www.cmhsoftware.com/symbol.htm
jeff.
Mike Swearingen 11-27-2006 08:29 AM
Thanks, Jeff!
I'll look for that inline thermal fuse to see if that's it. I assume that it's in plain view on the back of the refrigerator.
Mike
jeff1 11-27-2006 01:13 PM
Inside the freezer...between the icemaker and the wall wire plug.
jeff.
Mike Swearingen 11-29-2006 12:53 AM
Yo Jeff. I found it. Thanks.
However, I finally decided just to replace the whole ice maker after getting a closer look at it. It looked like there had been a burned short connection, the plastic in the ice tray was beginning to delaminate, etc., etc.
Called an area pro appliance repair guy from an adjoining county (we don't have one here locally), and he came over and replaced the entire unit today with one that he had in stock for $148.95 (about $85 for the ice maker and $64 +/- for the long distance service call and labor, I think). Didn't have to wait on one that I ordered.
Whatever. It was worth it to me. Problem fini. Wife happy, so I'm happy. LOL On to the next one.
Thanks again.
Mike
jeff1 11-29-2006 06:42 AM
If the fuse was open, above was likely the reason.
If Mama is not happy....nobody is happy! :laughing:
jeff.
mooseguns 05-24-2011 09:20 PM
What happens if I jump L-T
shameem007 06-09-2011 06:46 AM
Thanks, Jeff!
Mike
