Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 08-21-2010, 10:56 PM   #1
Whirlpool Ice Maker
I have the standard Whirlpool ice maker that is @ 10 years old. House struck by lightning and it stopped making ice. Tested the ports, water valve was fine, the motor stopped working. Bought a new motor and installed it. Waited a few minutes for the temperature to go down and the motor started to cycle. After 3 hours it fails to make any ice....the motor is still cycling and the ice maker spins in circles lifting the bar up and down. I have cycled the power on and off and also cycled the on-off bar on the ice maker itself....no joy. Anyone else have this happen when installing a brand new motor?
DanCarmo is offline   Reply With Quote
Old 08-21-2010, 11:12 PM   #2
" Euro " electrician
frenchelectrican's Avatar
Whirlpool Ice Maker
If the water valve is working good order { which it mean you actally see the water filling up the ice tray } if not then the motour is not lineing up with the mech part to sychrounous the whole thing and check the timing of the unit as well.
I know someone in this fourm is well versed so hang on someone will chime soon.
Last edited by frenchelectrican; 08-21-2010 at 11:15 PM. Reason: change format due OP mention water valve working
Whirlpool Ice Maker Control Kaput? Mike Swearingen Appliances 11 06-09-2011 07:46 AM
Kenmore (Whirlpool) refrig ice maker problem lexort Appliances 16 07-01-2010 03:00 PM
Whirlpool Fridge Ice Maker just quit igorlord Appliances 5 02-28-2009 08:49 PM
Whirlpool Ice Maker has stopped making ice jpetersen5 Appliances 7 04-13-2008 07:13 PM
Whirlpool Ice Maker Problem Aquin Appliances 5 03-26-2008 01:59 PM
