Whirlpool Ice Maker - Appliances - DIY Chatroom Home Improvement Forum
Old 09-30-2011, 07:30 PM   #1
whirlpool Ice maker
My refrig is 3 yeras old and the ice maker stopped making ice, something isn't right as it may make 1 tray in 24 hours. the temp is 15 degrees in space. I had a service man come out and he said that it was the compressor, I guess he could be correct but my gut feeling it isn't that.
The other day before we called the service company the ice cream was melting, so now it appears to get cold and then gets warm. I was thinking could it get into a defrost mode and gets stuck. ANY Help.....spent 1500.00 on that whirlpool hate to trash it .
john1949 is offline   Reply With Quote
Old 09-30-2011, 08:10 PM   #2
biggles's Avatar
might just try changing out the defrost timer before anything the tech should of picked it up the unit is prodiucing heat fromwith in...especially if the ice cream did get cold again...
The Following User Says Thank You to biggles For This Useful Post:
john1949 (09-30-2011)
Old 09-30-2011, 08:25 PM   #3
Where u from out there I was raised on Long Island, Levittown, but got transplanted down in Texas
Old 09-30-2011, 08:26 PM   #4
Where is the defrost timer ?
Old 10-01-2011, 03:44 AM   #5
Doubt it's the comp. yeah, frz temp too high for i/m. at that price point[$1500] it will have electronic controls. not DIY' for diag'. get another opinion.
Jacques is offline   Reply With Quote
Old 10-01-2011, 07:06 AM   #6
If the valves are leaking in the compressor he will never get the temp low enough to make sufficient ice, or freeze the ice cream hard.
Master of Cold is offline   Reply With Quote
Old 10-01-2011, 10:16 AM   #7
Got up this morning now temp at 20 degrees been closed all night,and it seems to be raising, in the freezer section the back wall has a panel where the cold air comes from should this be all ice on the coils.
Old 10-01-2011, 11:59 AM   #8
You will need to locate the defrost timer (somewhere on the bottom of fridge) and force it into defrost.
Old 10-01-2011, 01:06 PM   #9
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,582
doubt it has a defrost timer, most likely has an adaptive defrost board. Call in a different technician
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
Old 10-05-2011, 07:43 PM   #10
Definitely call a repair man. That is building up because your unit is noy kicking into defrost. The frost builds up and restricts air flow which causes the temperature to raise. The defrost system is definitely bad but out sounds like you need a repair man because your unit is not very diy friendly...
jfrotten is offline   Reply With Quote
Whirlpool (Kenmore) Ice Maker Slow... Juno1996 Appliances 2 09-20-2011 09:52 PM
Whirlpool Ice Maker Control Kaput? Mike Swearingen Appliances 11 06-09-2011 07:46 AM
whirlpool GS6SHEXNS00 ice maker not working houseof5dogs Appliances 1 05-06-2011 09:28 PM
Whirlpool Ice Maker DanCarmo Appliances 1 08-21-2010 11:12 PM
Whirlpool Ice Maker has stopped making ice jpetersen5 Appliances 7 04-13-2008 07:13 PM
