Whirlpool Ice Dispenser Not Dispensing - Appliances - DIY Chatroom Home Improvement Forum
Old 05-07-2011, 05:48 PM   #1
Question
Whirlpool Ice Dispenser not dispensing
We just moved into a home and the Whirlpool fridge ice maker makes ice just fine but won't dispense it.
I took the ice dispensing bucket out and found that the coupling spins freely from the motor. Is there a way to keep it in place so the motor can spin it and in turn, spin the bucket dispenser auger and push the ice out? I was thinking maybe some solder would keep in in place.
buddinc is offline   Reply With Quote
Old 05-07-2011, 08:53 PM   #2
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,600
Post a model#
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
Old 05-07-2011, 09:07 PM   #3
Post
Re: Post a model no.
Whirlpool refrigerator (side by side)
Model Number: ED5VHEXVQ00
Old 05-07-2011, 09:34 PM   #4
#1 HAWKEYE FAN
so if you turn it in a clockwise direction does it get tight on the motor or just spin, not sure on this one but it may be left hand threads. Either way it should tighten up on the motor, if not either the coupling threads are stripped or the threads on the motor. You'll have to figure out which one is bad and replace it. My bet is the coupling.
Old 05-07-2011, 09:39 PM   #5
Re: coupling
That's what I wondered. However, it does not loosen or tighten, it just spins and I can't get it off to look for a replacement. Is there another way to get that coupler off?
Old 06-13-2012, 09:14 AM   #6
Same problem
I was wondering if you found a solution. If not would a fine thread nut work? if so what size nut would it be.
coachclet is offline   Reply With Quote
Tags
ice maker auger coupling
whirlpool icemaker and water dispenser not working pal723 Appliances 3 03-18-2012 09:50 PM
whirlpool ice dispenser not working shadow07 Appliances 2 01-25-2011 07:19 PM
Whirlpool refrigerator ice dispenser lights Roy Rowlett Appliances 0 04-24-2010 02:07 PM
Whirlpool Ice Dispenser tommyb64 Appliances 9 04-24-2008 07:14 AM
Brand New Whirlpool fridge - Water dispenser stopped working!! jpherron Appliances 2 01-04-2008 01:35 PM
