Whirlpool Ice Dispenser - Appliances - DIY Chatroom Home Improvement Forum
Old 04-19-2008, 07:59 PM   #1
Hello All - I have a whirlpool gold side by side model # GS5SHAXNQ00. About three weeks ago a metal pin about 3" came out where the dispenser paddle is located along with a spring clip. It seems like it may be fairly easy to fix but I am not sure where or how to dismantle to get at the dispenser paddle. If anyone has experience or icemaker repair instructions with pictures, that would be great!
tommyb64 is offline   Reply With Quote
Old 04-19-2008, 08:26 PM   #2
jeff1's Avatar
Hi,
Something broke.
Can't be that easy then!
These may help...
PICTURE DELETED to make reading this thread easier.
http://www.applianceaid.com/ken_whirl_disp.html
http://www.applianceaid.com/ken_whirl_disp2.html
jeff.
Appliance Repair Aid
JRAppliance
www.jrappliance.ca
jeff1 is offline   Reply With Quote
Old 04-19-2008, 08:46 PM   #3
Ice Dispenser
This will be very helpful!
Thanks!
Old 04-19-2008, 11:29 PM   #4
jeff1's Avatar
Your welcome!
jeff.
JRAppliance
www.jrappliance.ca
Old 04-23-2008, 03:40 PM   #5
Ice Dispenser The Sequal
Hey Jeff!
Your diagram was very helpful. My icemaker is back in business but now my water dispenser does not work. Have you come across that problem before?
Thanks!
Old 04-23-2008, 04:36 PM   #6
jeff1's Avatar
The icemaker was broken? I thought the piece broke off of the dispensor?
Only since your repair?
No water -possible- trouble makers:
- frozen water tank/reservoir
- bad fill valve ( 1/2 is for icemaker and 1/2 is for chilled water )
- no power to the fill valve ( switch, mechanism in the dispensor )
jeff.
JRAppliance
www.jrappliance.ca
Old 04-23-2008, 08:33 PM   #7
No Water
Yes it has only been since the repair. I wonder if I did not get one of the plugs back in tight enough. There is the very thin plug that goes from the dispenser panel to the circuit board and two more that come out of the frig itself. If that is the case I am totally lost, electrical is not my bag. I will check them and see. Would the icemaker still operate if it were one of the other two options.... frozen water resevoir tank or bad fill valve. Where might the fill valve and tank be located?
Old 04-23-2008, 11:56 PM   #8
jeff1's Avatar
Then definetly check for a loose or "off" wire, misaligned mechanism for the chilled water paddle.
It should yes.
Icemaker makes the cubes, through the door dispensor is a seperate system.
Fill valve is normally at the back bottom. Water tank/reservoir is behind the crispers in the fresh food section.
jeff.
JRAppliance
www.jrappliance.ca
Old 04-24-2008, 12:24 AM   #9
Water Dispenser
Thanks once again Jeff. I will let you know how it goes.
Old 04-24-2008, 08:14 AM   #10
jeff1's Avatar
Great
jeff.
JRAppliance
www.jrappliance.ca
Frigidaire water dispenser does not work waywestside Appliances 4 09-27-2011 03:20 PM
Whirlpool Ice Maker Problem Aquin Appliances 5 03-26-2008 01:59 PM
Brand New Whirlpool fridge - Water dispenser stopped working!! jpherron Appliances 2 01-04-2008 02:35 PM
Frigidaire fridge water dispenser won't stop nonanon Appliances 1 10-05-2007 09:16 PM
