Whirlpool GS6HAXMB00 Not Cooling - Appliances - DIY Chatroom Home Improvement Forum
Old 10-07-2009, 08:14 PM   #1
whirlpool GS6HAXMB00 not cooling
My whirlpool GS6HAXMB00 is not cooling. The freezer section works just fine but the refrigertator side is not cooling at all. Presently the setting is at 7 and it not cool enough to keep my juices cold.I downloaded the owners manual but it did not show where the control board is located since I suspect this could be one of the cause. I have this refrigerator for almost three years and the warranty has run out. If someone with this kind of experince could give me some advice on how to solve this problem I would glady appreciate it. thank you.
Rogabo is offline   Reply With Quote
Old 10-14-2009, 08:16 PM   #2
not cooling
Check the damper. Located at the left rear top side of fridge. Probably frozen shut. Had a lot of trouble with those electronic ones in the past. Hope this helps
d scott is offline   Reply With Quote
Old 10-16-2009, 10:29 PM   #3
thanks for the reply. Air is flowing from the upper damper but I've notice the return damper between both drawers were frozen.I turn off the refrigertator and used a blow dryer to clear the passage but I've noticed it is frozen again. I believe it's a defrosting problem but not sure exactly what control should be at fault.
Fridge not cooling - evap fan? oppiecat Appliances 4 07-02-2013 05:19 PM
Help! Just changed my Fan Controler (ICM 275) now system "false starts" when cooling redmachodevil HVAC 4 01-26-2011 04:21 AM
Installation of Honeywell Thermostat - cooling function KDW Electrical 0 10-04-2009 10:56 AM
kenmore 596.58695890 cooling issues mindraven Appliances 7 08-22-2009 09:00 AM
Bad Whirlpool frig compressor? Guido Appliances 1 02-16-2008 09:18 AM
