Whirlpool Gold Series Icemaker Issues - Appliances - DIY Chatroom Home Improvement Forum
Old 04-11-2009, 02:35 PM   #1
Whirlpool Gold Series Icemaker issues
My icemaker on my whirlpool model # GS6NBERY 01 is not working. I have replaced the ice maker with a new one, but it is still not working. I manually put water into the unit and have tried to jumper the thing to trigger the harvest cycle, but not luck. I suspect the circuit board, but was wondering if anyone had any other ideas.
dirty dirk is offline   Reply With Quote
Old 04-11-2009, 06:17 PM   #2
Make sure the electronic sensors or not blocked they should have a clear shot from on side of the ice bin to the other. If they are not blocked replace them.
Last edited by Scuba_Dave; 09-30-2010 at 11:46 AM. Reason: removed adv link in post
applianceman is offline   Reply With Quote
Old 05-15-2011, 11:32 AM   #3
gold series Ice Maker issues
I bought a gold series fridge Model: GI7FVCXWYOO from sears scratch & dent store. After bout 3 months the ice maker started working intermittently then quit althoghter. After testing every switch, selenoid & connection it all came down to a simple connection that contains the water tubes on back of the fridge. I found that the wiring is barely enough to make the connections that something(heat Maybe)is causing a loose connection. So, even though there is a purpose that it's screwed onto the back panel. I took it off, and gently squeezed each female connection and just loosely wire tied that group off the connections and tubing so that it's out of the way of the fan blades. The ice maker problem hasn't visited me since. Thank goodness. Now, this may be just my fridge that this querky problem was remedied, but it's something that I just gotta put out there....
jesse135 is offline   Reply With Quote
whirlpool icemaker and water dispenser not working pal723 Appliances 3 03-18-2012 09:50 PM
whirlpool icemaker wiring question dannyb Appliances 3 03-28-2009 08:45 PM
Whirlpool icemaker advice diymomof4 Appliances 2 11-30-2008 08:10 PM
Whirlpool Icemaker Stopped Working jablizz General DIY Discussions 1 07-19-2008 08:38 PM
whirlpool icemaker problem pbl1962 Appliances 2 12-26-2007 02:07 PM
