Whirlpool Gold Dishwasher Not Draining All The Way - Appliances - DIY Chatroom Home Improvement Forum
Old 03-26-2015, 07:29 PM   #1
Rewards Points: 18
Whirlpool gold dishwasher not draining all the way
I have a whirlpool dishwasher model gu1500xtkq0, that is not draining out all the way. Once the cycle is over, there is still a good 2 inches of water left in the bottom. I first thought it was the check valve. Inspected it and it looked fine. So I'm thinking it is the drain pump that has gone out. I have found the pump on line for about $35. How involved is it to replace? Or could it be something else the matter with the washer?
Gburg109 is offline   Reply With Quote
Old 03-26-2015, 07:51 PM   #2
Rewards Points: 582
make sure the drain hose is properly installed..and not sagging...
Old 03-26-2015, 07:51 PM   #3
Rewards Points: 252
Repair clinic has a link (click on link below) with the 5 most common drain problems for your dishwasher. Click on part replacement video under each problem for more information. Simple fix, pretty straight forward.
As Ben has suggested, could also be the drain hose.
http://www.repairclinic.com/RepairHe...in-GU1500XTKQ0
jmon is online now   Reply With Quote
Old 03-26-2015, 08:17 PM   #4
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,600
I wouldn't replace the pump until you inspect the drain hose for an obstruction.
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
Sink Draining into dishwasher majch Plumbing 21 06-22-2014 11:54 AM
Whirlpool dishwasher not draining JoeLena Appliances 2 05-03-2013 03:38 PM
Dishwasher not draining properly llmercll Plumbing 15 02-08-2011 10:24 PM
Dishwasher draining & water supply Murphy522 Plumbing 2 11-18-2009 08:51 AM
Help Dishwasher Draining Problem swicks15 Plumbing 2 09-21-2008 12:58 PM
