Whirlpool Gas Dryer Mod LGR7647 - Appliances - DIY Chatroom Home Improvement Forum
Old 02-01-2011, 04:13 PM   #1
Whirlpool gas dryer mod LGR7647
I want to know how to get into the cabinet. It looks like I have to take off the panel in the back. This dryer is about 11 years old. Does anyone know where I can download the manual. I've tried several sites without success. All the manuals I've seen so far cover several models.
crhtjhn is offline   Reply With Quote
Old 02-01-2011, 09:27 PM   #2
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,588
the back will come off, back there you have access to the heating element and thermostats, if you want anything else you have to take off the front. open the lint filter cover and remove those 2 screws you see, take a putty knife and find 2 releases tabs in the front of the top panel, lift top, look down into the dryer and locate 2 screws that hold the front panel on, remove them and then you can lift the front panel off. you now have access to everything
hardwareman is offline   Reply With Quote
Old 02-01-2011, 09:59 PM   #3
#1 HAWKEYE FAN
oops, should have read your post better, since its gas disregard removing the back panel, aint nothing there.
Old 02-15-2011, 10:47 AM   #4
Whirlpool gas dryer Mod LGR 7647
Just repaired mine. Hardwareman, you are too hard on yourself. Going through the back was actually right on the money. I laid the dryer on its side and thus avoided disconnecting the gas,(although I still shut it off) It came off easily. In checking the continuity of the three electrical sensors, I found that the thermal fuse was the problem. Replaced it ($12 plus shipping) and everything worked fine.
Whirlpool gas clothes dryer not heating ??? What have I done Appliances 5 10-19-2010 01:19 PM
Whirlpool electric dryer won't shut off. quigleybmd Appliances 1 09-27-2010 08:27 PM
Problems with Whirlpool Dryer Hookup! Help! maryrgrimm Appliances 1 04-07-2010 08:42 AM
Worth fixing whirlpool estate elect. dryer? dbldee20 Appliances 2 05-10-2009 05:40 PM
Whirlpool electric dryer won't heat jpplumber Appliances 5 01-13-2008 11:21 PM
