Whirlpool Gas Clothes Dryer Not Heating ??? - Appliances - DIY Chatroom Home Improvement Forum
Old 04-05-2010, 08:13 PM   #1
Rewards Points: 266
Whirlpool gas clothes dryer not heating ???
Where should I start? Whirlpool Gas dryer stopped heating and is not drying the clothes. All other gas appliances are working fine. Where should I start to look?
What have I done is offline   Reply With Quote
Old 04-05-2010, 10:58 PM   #2
Remodeling Contractor
first check that the lint filter is cleaned. next inspect the duct and vent lines and the cap on the exterior.
Old 04-06-2010, 01:05 PM   #3
Rewards Points: 266
All checked and clear. We are pretty anal about cleaning the filter with every load. No build-up seen in the pipe exiting the dryer to outdoors.
Whats the most common problem with gas dryers? ignitor or something else? Tonight I plan on taking the dryer out so I can get a good look around.
Any suggestions are greatly appreciated
Old 04-07-2010, 07:56 AM   #4
Rewards Points: 266
Well last night I took the dryer out of the laundry room so I had room to work. Opened up the cabinet, vacuumed everything out real well. Pocketed the loose change I found.
moved it back into place still no heat. it can never be that easy!
Researched internet and found the likely culprit to be the THERMAL fuse.
I found that when I removed it there was a wad of lint stuck to the backside of it. I jumpered the blown fuse and the dryer fired right up.
Called the service center and the fuse can be gotten for less than $10. So I am happy as can be and we can get back to doing the laundry.
Old 10-18-2010, 10:27 PM   #5
where is the thermal fuse located
sandlylf is offline   Reply With Quote
Old 10-19-2010, 12:19 PM   #6
HVAC / Plumbing
back of the dryer
kenmac is offline   Reply With Quote
clothes dryer sucking all my cool air outside shank General DIY Discussions 6 08-02-2012 09:01 PM
Worth fixing whirlpool estate elect. dryer? dbldee20 Appliances 2 05-10-2009 04:40 PM
Whirlpool electric dryer won't heat jpplumber Appliances 5 01-13-2008 10:21 PM
Clothes Dryer / Outlet homercavazos Electrical 8 10-30-2007 04:14 PM
electric dryer heating element gooch Appliances 2 03-27-2007 09:31 PM
