Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 12-28-2011, 12:49 PM   #1
Mechanical Engineer
Whirlpool frig, condensation problem
I have a standard Whirlpool fridge, freezer on top, frig on the bottom, 21 cu. ft., model # ET1CHMXKQ06. We have been getting water buildup inside the fridge. Not small drops, but small puddles of water on the bottom of the fridge, and inside the drawers. It seems to be coming from the ventilation opening in the fridge compartment, directly behind the controls, near the back of the fridge.
I cleaned the condenser coils on the bottom of the fridge, from front and back. They were enormously dirty and covered with lint, dirt and hair. After 24 hours, the problem seems to remain. I searched here, and found that it might be a clogged drain. While cleaning the coils, I noticed that the condensate tray was completely dry. Seems logical.
I see where the condensate tube exits the fridge, above the condensate tray in the back, but I don't know where it starts inside the fridge/freezer. I was going to try and clean the tube with a piece of wire or a turkey baster, but I'm not sure where to start looking.
Thanks in advance. Happy New Year!
gshock is offline   Reply With Quote
Old 12-28-2011, 01:45 PM   #2
http://www.appliancerepair.com/Appli...gerator-Repair
Old 12-28-2011, 01:52 PM   #3
Mechanical Engineer
I forgot to mention, the ice maker is not connected, and the metal bar is in the "Off" position.
Old 12-28-2011, 05:28 PM   #4
To answer you question the begining of the drain line is going to be in your freezer section behind the back wall. Open your freezer and locate the screws holding the back panel/wall on. Behind this wall is your evaporator coil. This is where you will find the drain line and problem causing water build up In fridge. With my experience upon removing. The back wall you will find that the drain pan will be filled with ice blocking drip line hose . Take a hair dryer or heat gun to it to remove ice and you will be good to go . If you have a questions you can find my number at http://www.ACESTARSERVICES.com
acestarservices is offline   Reply With Quote
The Following User Says Thank You to acestarservices For This Useful Post:
gshock (12-29-2011)
Old 12-28-2011, 06:37 PM   #5
#1 HAWKEYE FAN
hardwareman's Avatar
ace is mostly right. First never use a heat gun, it gets way to hot. Use the hair dryer and hot water to get the drain open. Second, once you get it unthawed you will want to make yourself a heat transfer strap to put down the drain line to keep it from doing it again, because it will do it again.
If you want to make the strap let me know and I'll tell you how.
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
The Following User Says Thank You to hardwareman For This Useful Post:
gshock (12-29-2011)
Old 12-29-2011, 10:00 AM   #6
Mechanical Engineer
Ace, thanks for the advice. That worked great. I just used hot water and a turkey baster until I cleared the ice. Everything seems to be working well.
Old 12-29-2011, 10:08 AM   #7
Mechanical Engineer
hardwareman, appreciate the advice. I'm interested in making the heat transfer strip. I'm assuming that it's a means to transfer heat during the defrost cycle to keep the drain opening clear. Do you connect it to a particular spot on the evaporator coil?
Thanks for the advice.
Old 12-29-2011, 12:54 PM   #8
#1 HAWKEYE FAN
yes, to make it I like to use about a 6" long 1/4" strip of aluminum but you can use a peice of #9 wire also. Form a little loop on one end and attach it to the defrost heater. Position the other end down the drain tube then tighten the loop on the heater so it makes good contact. This will keep your problem from returning.
gshock (12-29-2011)
Old 12-29-2011, 12:58 PM   #9
Mechanical Engineer
Nice. Thanks for the tip. I don't have any #9 wire, but I wonder if it would work just as well if I twisted 2 #14 wires together.
I wasn't paying close attention to the heating element on the evaporator when I had the panel off. Do you know it it's on the right or the left? I'm assuming it's just a bare wire that contacts the evaporator coil, correct?
Thanks again. Happy New Year!
(Ah, now it makes sense ... the aftermarket Whirlpool strap looks very similar, just a flat piece of aluminum and a screw. Just can't recall from memory where it might attach behind the panel)
Old 12-29-2011, 07:30 PM   #10
#1 HAWKEYE FAN
the defrost heater is attached to the bottom of the evap coil. It runs the entire lenghth from left to right.
gshock (01-02-2012)
Old 12-29-2011, 09:39 PM   #11
Glad it worked .
Old 01-02-2012, 06:39 AM   #12
Mechanical Engineer
Gentlemen, thank you for all the help. Best wishes for 2012!
whirlpool oven problem ElectricianJeff Appliances 0 09-27-2010 05:41 AM
Kenmore (Whirlpool) refrig ice maker problem lexort Appliances 16 07-01-2010 03:00 PM
Neutral problem, not sure what to do now BataviaJim Electrical 37 01-03-2009 12:00 PM
Sweating windows big daddy-o General Discussion 15 01-06-2008 03:41 PM
whirlpool icemaker problem pbl1962 Appliances 2 12-26-2007 03:07 PM
