Whirlpool Fridge Water Dispenser Dumps Water Every 15minutes - Appliances - DIY Chatroom Home Improvement Forum
Old 10-16-2013, 04:47 PM   #1
whirlpool fridge water dispenser dumps water every 15minutes
Bought a floor model whirlpool fridge from an appliance reseller. Manufacture date is 2013. Get the thing home and hook it up and everything seems fine. Then every 15minutes or so the water dispenser on the door shoots water out. Like theres a poltergeist trying to get water. Im amazed a new fridge could have an issue like this.
Its got a digital display on the water dispenser for the flitration and temp settings and all that
Model is: WRF560SEYWoo
Any help/ideas appreciated
EVOL is offline   Reply With Quote
Old 10-16-2013, 07:21 PM   #2
Rewards Points: 14,312
I'd start by checking the incoming water pressure, to high or to low and it will cause the valve to malfunction.
Next I'd check the incoming power to the valve.
http://www.repairclinic.com/PartDeta...epairHelp=True
Old 10-16-2013, 08:24 PM   #3
chitownken's Avatar
Rewards Points: 510
Does it have an icemaker? And if it does, is the icemaker making ice?
chitownken is offline   Reply With Quote
Old 10-16-2013, 08:43 PM   #4
Remodeler
Rewards Points: 330
There should be two solenoid valves in the back where the water line connects. One supplies water to the ice maker, the other to the water dispenser.
Possibly either the wires that activate the valves or the water lines from the valves were reversed during assembly, when the ice maker is calling for water to fill, water shoots from the door dispenser.
Does the ice maker work correctly?
iamrfixit is offline   Reply With Quote
vacuum breaker question detroittigerfan Plumbing 17 10-12-2013 01:37 PM
Low hot water pressure crebive Plumbing 38 02-26-2013 12:26 AM
New hookup water and ice dispenser not working billybarty Appliances 6 02-18-2011 07:34 AM
Frigidaire water dispenser - slow flow Handy Dandy Appliances 1 01-18-2011 11:02 PM
Thru Door Water Dispenser Stopped lemonyx Appliances 1 01-25-2010 07:45 PM
