Whirlpool Fridge Not Cooling - Appliances - DIY Chatroom Home Improvement Forum
Old 11-20-2011, 05:52 PM   #1
ltd
Rewards Points: 536
whirlpool fridge not cooling
ok, about 2 year old fridge still looks like new .the top freezer is still keeping food frozen but with a slight frost over the ice and wrapped food .the bottom is only chilled at best .under the fridge is all clean .i don't think i'm losing any refrigerant but hey what do i know. what i do know is the compressor does not cycle on enough. i would like to fix this fridge ,not me but a repair man does this sound like something that can be fixed for a reasonable amount ?
ltd is offline   Reply With Quote
Old 11-20-2011, 07:37 PM   #2
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,600
Originally Posted by ltd View Post
o. what i do know is the compressor does not cycle on enough.
what do you mean by that? and how do you know?
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
Old 11-20-2011, 07:52 PM   #3
ltd
Rewards Points: 536
its just not kicking on as frequent as it use to the fridge sits quiet for long periods of time
Old 11-20-2011, 09:35 PM   #4
I'm Your Huckleberry
Rewards Points: 2,270
The repair man is going to have determine if there is a good refrigerant charge,if all of the switches are working right and the correct voltage and amp draw. If the compressor is trying to start but is not (it may hum or make a rattling noise if it's trying) then there is a hard start kit for small compressors that can be added to the compressor circuit which ensures it starts when it tries.
Doc Holliday is offline   Reply With Quote
The Following User Says Thank You to Doc Holliday For This Useful Post:
ltd (11-20-2011)
Old 11-20-2011, 10:47 PM   #5
#1 HAWKEYE FAN
if it is not kicking on like it is supposed to, I would suspect a bad cold control. Or if you have electronic controls you may have a bad sensor or circuit board.
The Following User Says Thank You to hardwareman For This Useful Post:
ltd (11-21-2011)
Help My Admiral Refrigerator is leaking water Cuwillis Appliances 10 03-25-2014 08:21 AM
Fridge not cooling - evap fan? oppiecat Appliances 4 07-02-2013 04:19 PM
Kenmore fridge stops cooling with frost in freezer donnoit Appliances 3 09-20-2010 07:59 AM
Kenmore fridge not cooling, freezer ok bobvanhalder Appliances 20 10-22-2008 11:36 PM
Kenmore fridge not cooling, freezer ok bobvanhalder HVAC 7 10-22-2008 10:52 PM
