-   -   whirlpool fridge not cooling (http://www.diychatroom.com/f47/whirlpool-fridge-not-cooling-124094/)
ltd 11-20-2011 05:52 PM
ok, about 2 year old fridge still looks like new :) .the top freezer is still keeping food frozen but with a slight frost over the ice and wrapped food .the bottom is only chilled at best:( .under the fridge is all clean .i don't think i'm losing any refrigerant but hey what do i know:huh:. what i do know is the compressor does not cycle on enough. i would like to fix this fridge ,not me but a repair man does this sound like something that can be fixed for a reasonable amount ?
hardwareman 11-20-2011 07:37 PM
Originally Posted by ltd (Post 775562)
o:huh:. what i do know is the compressor does not cycle on enough.
what do you mean by that? and how do you know?
ltd 11-20-2011 07:52 PM
its just not kicking on as frequent as it use to the fridge sits quiet for long periods of time
Doc Holliday 11-20-2011 09:35 PM
The repair man is going to have determine if there is a good refrigerant charge,if all of the switches are working right and the correct voltage and amp draw. If the compressor is trying to start but is not (it may hum or make a rattling noise if it's trying) then there is a hard start kit for small compressors that can be added to the compressor circuit which ensures it starts when it tries.
hardwareman 11-20-2011 10:47 PM
if it is not kicking on like it is supposed to, I would suspect a bad cold control. Or if you have electronic controls you may have a bad sensor or circuit board.
